Newer oil pump on an older engine.
I have a 1970 429 that I would like to put a Meling M-84D oil pump on. Any suggestions for the correct pickup to use on it?
I have a front sump pan that will go into a 75 ford f250 truck.
https://2img.net/h/i1214.photobucket.com/albums/cc484/foto41/IMG_2745.jpg
75truck- Posts : 102
Re: Newer oil pump on an older engine.
75truck wrote:I have a 1970 429 that I would like to put a Meling M-84D oil pump on. Any suggestions for the correct pickup to use on it?
There is no Ford Motor Company pick-up ... get that pick-up from CANTON.
Although that photo looks like a Cobra Jet oil pan and that pump and pick-up combination is still available.
Ok - Called Canton and got the 15-763 pickup. Should fit on a std front sump pan.
Thanx for help and direction.
Bob
Tucson
Bob
Tucson
I got one of those Canton 15-763 pickups , they are specifically for the rear type pump to a front sump so should do you well.
In my case i needed a 15-761 for a Kaase pump to front sump which unfortunately I don't think they make any more but i found one on eBay
The 15-763 will go in my next motor
Gregaust- Posts : 625
Gregaust wrote:I got one of those Canton 15-763 pickups , they are specifically for the rear type pump to a front sump so should do you well.
Kaase offers his pumps in both configurations ... the Cobra Jet style and the rear facing pick-up style.
I already had the Kaase pump for the CJ style pickup so was lucky to track down the right pickup . Next time I'll get the other one for the rear sump and use this pickup
» fuel pump 600 hp give or take .. best bang for the buck
» 466 pump gas street engine HP/Torque results
» help w/ 545 stroker and engine components , 9.5:1 pump gas, 600hp N/A
» Looking for pics of engine plate with power steering pump
» 572 P-51 Pump Gas Street Engine
