Cam bolt suggestion.
FORDMUD
75truck
Just ordered a Bullet Cam for my 429. I had them drill the end to 7/16x20 instead of the original 3/8 bolt.
Arp doesn't have that bolt size. Any suggestions of where to get one?
Bob
Tucson
Bob
Tucson
75truck- Posts : 102
Re: Cam bolt suggestion.
You can buy bolts in various lengths and sizes from ARP in 5 packs. I bought the part number 743-1500. I also used a sbc crank bolt washer. Double and triple check that the non threaded shank isn't hitting the threads before you get maximum clamping.
FORDMUD- Posts : 290
The washer is just as important as the bolt (thick and hardened). I use a grade 8 socket head cap screw and lock tight.
Grade 8 bolt or ARP 8740 rod bolt and a Chevy Small Block crank bolt washer works well.
DaveMcLain- Posts : 399
75truck wrote:Just ordered a Bullet Cam for my 429. I had them drill the end to 7/16x20 instead of the original 3/8 bolt.
Bob
Tucson
ARP makes and offers about 20 different rod bolt cap screws which are that size.
Or this place http://www.specialty-fasteners.com/ has everything you need .
Gregaust- Posts : 626
Lem Evans at BF Evans Ford keep the correct hardware instock too.
» Best 4-Bolt caps/DOVE-A 2 Bolt
» Intake and camshaft suggestion
» Rocker Arm (upgrade) suggestion for A-460 Heads
» Ring and bearing suggestion needed.
» Valve size suggestion for d0ve heads
