Broken oil pump pickup
bbcoupe
Broken oil pump pickup Empty Broken oil pump pickup
Post  bbcoupe June 20th 2016, 11:36 pm
My oil pressure gauge started bouncing up and down and short story is this is what I found when I removed pan.
Anyone else experienced this and can share what the cause and remedy is?
Broken oil pump pickup 20160620_191450_zpsljvdaju5
Broken oil pump pickup 20160620_192347_zpsk2ysg3x0
Broken oil pump pickup 20160620_192434_zps4bax6yqu
bbcoupe
https://www.youtube.com/user/coupe545
Broken oil pump pickup Empty Re: Broken oil pump pickup
Post  FalconEh June 20th 2016, 11:42 pm
bbcoupe wrote:My oil pressure gauge started bouncing up and down and short story is this is what I found when I removed pan.
Did the pickup have a bolt strap to a main bolt..."edit" looking closer at the pictures it looks like a front sump, but the weight of the pickup can cause stress on the weakest point, many tack weld the front sumps as the rear sumps are bolted with a strap to a main bolt/stud.
Last edited by FalconEh on June 20th 2016, 11:58 pm; edited 1 time in total (Reason for editing : front sump)
Post  69BOSS June 21st 2016, 1:41 am
is that a us made part or is it an import?
69BOSS
69BOSS
Post  D. Sea June 21st 2016, 8:10 am
I'm in R&D and we do a lot of vibration testing. That looks like a tube failure due to vibration i.e. The tube and pickup are "Shaking" at or near it's natural frequency which will fatigue the part and then form a crack which will then result in a complete failure over time.
D. Sea
D. Sea
Post  cool40 June 21st 2016, 9:07 am
My guess is that looks like a cj type pickup with probably a standard pan.it wouldn't have quite enough clearance so someone bent the tube a little so the pan would go on and unknowingly cracked the tube. Suspect
Post  gt350hr June 21st 2016, 10:58 am
I've never seen one break there in all the years I've been doing this.
gt350hr
Post  bbcoupe June 22nd 2016, 7:44 am
cool40 wrote:My guess is that looks like a cj type pickup with probably a standard pan.it wouldn't have quite enough clearance so someone bent the tube a little so the pan would go on and unknowingly cracked the tube. Suspect
It's an aftermarket pan and has been used with this pickup for 9years.
Broken oil pump pickup P1250048_zpsxkgk3fxm
bbcoupe
Post  cool40 June 22nd 2016, 10:20 am
In that case maybe it just broke? scratch
