Engine Build Manual
Engine Build Manual
I have a 2003 Ford racing 460cid crate engine (M-6007-B460) fitted with CobraJet Alum. Heads and Victor Jr inlet, Holley double pumper. I need to get a good workshop manual for this engine, one that includes bolt torques, clearances etc. This is so I can initially remove and refit the inlet manifold to cure a small constant coolant weep I have.
Can anyone point me to one.
Thanks Alex. UK
Thanks Alex. UK
RedDragonCobra- Posts : 7
Re: Engine Build Manual
RedDragonCobra wrote:I have a 2003 Ford racing 460cid crate engine (M-6007-B460) fitted with CobraJet Alum. Heads and Victor Jr inlet, Holley double pumper. I need to get a good workshop manual for this engine, one that includes bolt torques, clearances etc. This is so I can initially remove and refit the inlet manifold to cure a small constant coolant weep I have.
Thanks Alex. UK
There is none for an engine such as that however, a Chilton's Manual available for a 90's 460 F.I Truck engine from a place like O'Reilly's Auto Parts will get you what you need It will have PRODUCTION clearances, not race engine tolerances.
This one will get you started.
https://www.amazon.com/Ford-Performance-Pat-Ganahl/dp/1884089275
hienergy557- Posts : 179
hienergy557 wrote:This one will get you started.
Just keep in mind with those books a lot of the performance tips are outdated
But they are ok for basic info
» Help with a 460 EFI engine build.
» Help me build my engine!
» Hey y'all! Got some engine build q's
» engine build ?
» engine build ?
