rocker arm girdle when is it worth while or needed
+7
5pointslow
BigDave65
torino501
11 posters
rocker arm girdle when is it worth while or needed  Empty rocker arm girdle when is it worth while or needed
Post  5pointslow July 7th 2016, 1:13 pm
this is vague but when is it needed or good to have a rocker arm stud girdle like the jomar or crane sells
is it Rpm ? or camshaft /spring pressure ?
im using eddelbrock heads with harland sharp rocker arms shouldnt turn anymore than 6500-6700 rpm
anyones input on this greatly appreciated and any preference on brand if needed ?
adjusting lash the same with or with out ?
Id rather not have to use one , but if needed i would get one
5pointslow
5pointslow
rocker arm girdle when is it worth while or needed  Empty Re: rocker arm girdle when is it worth while or needed
Post  torino501 July 7th 2016, 1:50 pm
id say anything over 180 psi of seat pressure...yes.
torino501
Post  BigDave65 July 7th 2016, 2:16 pm
I ran a .750 lift roller cam with about 220# of spring on the seat, don't remember what open was, without a girdle, and never had any valvetrain issues. I went to a .800 lift cam that was a little more aggressive with a little more spring and decided to use a girdle with that set-up.
BigDave65
BigDave65
Post  dfree383 July 7th 2016, 3:50 pm
We have found 10-12 hp using them
Post  rmcomprandy July 7th 2016, 7:01 pm
NEED is defined differently to different people.
Just because not having one won't necessarily lead to valve train breakage does not mean it would not be a benefit for one to be there..
Post  maverick July 7th 2016, 8:13 pm
rmcomprandy wrote:NEED is defined differently to different people.
^^^^^^^^^^^^^^^^^|^^^^^^^^^^^^^^^I find my stud girdles help me sleep better^^^^^^^^^^^^^^^^^^^^^^
Post  5pointslow July 8th 2016, 8:45 am
thanks for info just didnt know when there is "need" , seems more of a preference to some when to use
5pointslow
5pointslow
Post  5pointslow July 8th 2016, 8:46 am
i figuare it wouldnt hurt having one , but adjusting valves any more involved or same thing didnt know if it was a pain in the a$$
5pointslow
5pointslow
Post  rmcomprandy July 8th 2016, 10:52 am
If you don't want a more stable valve train
If you don't want the extra power available
If you don't want the extra protection against pulling a stud
If you don't want a longer life for parts involved
If you don't want that extra piece of mind against breakage
Then you don't NEED one.
Post  5pointslow July 8th 2016, 12:01 pm
rmcomprandy wrote:If you don't want a more stable valve train
5pointslow
5pointslow
Post  HorsinAround November 5th 2016, 5:44 pm
Can some one recommend one for a A429 heads? I have used a comp and currently have crane and am not impressed with the alignment of either.
http://www.frontpagefab.com
Post  Mark O'Neal November 5th 2016, 6:20 pm
5pointslow wrote:thanks for info just didnt know when there is "need" , seems more of a preference to some when to use
Whenever the rocker stud starts to deflect.
Which happens to some degree when you engage the starter.
Mark O'Neal
Post  dfree383 November 5th 2016, 6:23 pm
HorsinAround wrote:Can some one recommend one for a A429 heads? I have used a comp and currently have crane and am not impressed with the alignment of either.
rockers or girdles ?
Post  HorsinAround November 5th 2016, 6:31 pm
Rocker girdle
Post  Doug Rahn November 5th 2016, 6:37 pm
If you're referring to stud girdles use Jomar. If memory serves me correctly from other inquires in past years there was a machining issue with the early heads so Jomar makes two part numbers to deal with both early and later heads. So you will need the serial numbers off your heads to get the right one, and as far as I know they are the only ones that offer that option.
Post  norm November 5th 2016, 6:38 pm
I used Jomar girdles on mine. You need to know the serial number on your heads, they have 2 different girdles depending on early or late.
norm
norm
Ha! i type too slowly.
norm
norm
Post  HorsinAround November 5th 2016, 6:42 pm
Saw that on their web site today. Just so happened that I had the covers off so I was able to get the serial number.
Post  69F100 November 5th 2016, 7:18 pm
I have a set I bought for mine the comp cam brand but they don't fit mine the valve angle is a little off. I can get the number off of them to see if they will fit yours I bought them off here he said he had them on a set of a429 heads.
