Mud Racing 1979 ford gearing setup ????
mudtrucker
kjett
crittersf1
racinghabbit
1979 ford shortbox , 44 front 9 rear. 205 tcase, c6 trans.... 38 skinny boggers.... 180 length mud pits 8-18 inch deep... playing around with gears... What differential gears are some others running?
racinghabbit- Posts : 575
Re: Mud Racing 1979 ford gearing setup ????
I run 5:13's front and rear
crittersf1- Posts : 521
in high or low range?
Me too, in low range. Made the swap from the 38/39.5 combo to 42" boggers and I'm noticeably faster this year.
kjett- Posts : 1169
I'm not at all trying to start a keyboard battle I'm just trying to figure out the gears for my new build. You have always pushed the 10:1 final drive and not wheel speed. With My 466 I ran a 10.47:1 and it worked very well. But if you went from a 39.5 to a 42 you changed the ground speed (mph) by at least 5mph if you are turning the same rpm. I am going from a 466 to a 545 or 557, so with the increased torque and prob few hundred less rpm I cant see the same final drive working as good.kjett wrote:Me too, in low range. Made the swap from the 38/39.5 combo to 42" boggers and I'm noticeably faster this year.
mudtrucker- Posts : 160
I still do. I've said don't sweat the wheel speed as much as getting the final drive ratio correct. By me going to the taller tire, I still have my 10:1 final drive, I just increased the ground speed by going with the taller tire that has a longer roll out. Clear as mud?
kjett- Posts : 1169
Does anyone run highrange?
You changed from the 5.43's?
68formalGT- Posts : 865
What kind of hp do you think you are putting out?
460bronco- Posts : 364
is going from 4.88 to 4.10 a really big jump?
Do you have the horsepower to turn the tire in the mud and not bog down in rpm?
Pretty sure I told you what gears I use to run and won't say on here again but try it you will be very surprised. It's not the gears or the transmission or the tire size or the motor size that matters! It is all of them put together in a combination with a good suspension that will make your truck fast!!!! My best advice is change one thing at a time and log your results to see where your at and when you find the combo that you think works keep changing small things, even try some old parts over because once one thing changes ten others may need to be adjusted to get optimal performance from it. But always keep records of your changes and what they did to the truck!
lghting94- Posts : 762
sent you a pm lghting94lghting94 wrote:Pretty sure I told you what gears I use to run and won't say on here again but try it you will be very surprised. It's not the gears or the transmission or the tire size or the motor size that matters! It is all of them put together in a combination with a good suspension that will make your truck fast!!!! My best advice is change one thing at a time and log your results to see where your at and when you find the combo that you think works keep changing small things, even try some old parts over because once one thing changes ten others may need to be adjusted to get optimal performance from it. But always keep records of your changes and what they did to the truck!
Muddy557- Posts : 11
» 1979 ford f-250 4+4
» 1979 Ford F150 Drag Week Build
» 1979 Ford F150 2WD with 460 BBF
» Selling my 1979 Ford F150 4X4
» 1979 Ford 400M engine
