611 ci Thor head build
611 ci Thor head build Empty 611 ci Thor head build
Post  Scott Foxwell August 17th 2016, 8:25 pm
Built this recently for a truck pull customer.
611 ci, 4.65 x 4.5
Eliminator block
Scat billet crank
Oliver rods
17:1 Diamond pistons, thermal coated crowns, Line2Line coated skirts
.25 wall DLC coated Trend pins
.043 .043 3mm Total Seal rings
Thor heads ported by CFE
2.48/1.86 REV custom Ti valves
Pac dual 1.50" springs
T&D stainless rocker assembly
Smith Brothers 1/2" push rods
Morel DLC coated .936 keyway lifters in CHE bushings
Straub custom 60mm cam
Danny Bee belt drive
ATI damper
Stefs Pro Stock dry sump pan
Aviaid 6 stage dry sump; 3 in the pan, one in the valley and one for vacuum
Aero vac pump
CFE sheet metal intake
AED custom billet 2.30 throttle bore Dominators
Crane HI8 ignition
Machine work flawlessly performed by Bob Myers & son at Performance Machine
This engine was a nightmare to build.
1440hp @ 8000
1030 tq @ 6700
611 ci Thor head build 13177204_1096223137108168_7169718941380148427_n
611 ci Thor head build 11866487_948122175251599_2647642551908909420_n
611 ci Thor head build >oh=fdb33e7d7659e9b7d11a3d0a15145088&oe=5845044C
611 ci Thor head build 11220787_948123105251506_3795756937378781934_n
611 ci Thor head build Empty Re: 611 ci Thor head build
Post  Scott Foxwell August 17th 2016, 8:32 pm
611 ci Thor head build 11062790_948123288584821_1151312092278252252_n
611 ci Thor head build 11825573_941266649270485_473549562860137565_n
611 ci Thor head build 10984250_941266652603818_1748514952884953533_n
611 ci Thor head build 11143660_941266689270481_7547821101740857229_n
611 ci Thor head build 11811459_941266722603811_537537808545354957_n
611 ci Thor head build 11760127_932657966798020_8189969386859274122_n
611 ci Thor head build 11038987_932658043464679_7355855156527015489_n
Post  Scott Foxwell August 17th 2016, 8:42 pm
611 ci Thor head build 10421187_887360087994475_96808304038268419_n
611 ci Thor head build 11138584_887360264661124_3272939972894668890_n
611 ci Thor head build 2015-10-07_18-26-20
611 ci Thor head build 2015-10-07_18-46-43
611 ci Thor head build 2015-10-07_18-26-22
611 ci Thor head build 2015-10-07_18-26-24
611 ci Thor head build 11103000_879222175474933_8891273465028480297_n
611 ci Thor head build 2015-10-07_19-13-29
611 ci Thor head build 2015-10-07_19-02-48
Post  Scott Foxwell August 17th 2016, 8:55 pm
611 ci Thor head build 12112069_975271075870042_8154991766786234745_n
611 ci Thor head build 11139995_975271099203373_2831223261601485743_n
611 ci Thor head build 12109259_975271145870035_5993013786959353029_n
611 ci Thor head build 12088233_975271225870027_328253908972818377_n
611 ci Thor head build 12122509_975271292536687_717625116720745859_n
611 ci Thor head build 12118761_975271342536682_2224964050370321891_n
611 ci Thor head build 11737922_932664483464035_7015959608334014594_n
Post  larry552 August 18th 2016, 7:46 am
very nice build
larry552
larry552
Post  68formalGT August 18th 2016, 8:40 am
Very nice!!
Post  738drvr August 18th 2016, 10:31 pm
Wow. How much?
That's one bad bullet.
Post  crittersf1 August 19th 2016, 2:13 pm
Really nice!!!
crittersf1
crittersf1
