Torque value on oil pump
Have a 84-d oil pump I'm putting on a 429.
What is torque spec for the 1/4" cover bolts?
What is torque specs for the 2 mounting bolts?
Is it suggested that studs be used instead of the mounting bolts.
75truck- Posts : 102
Re: Torque value on oil pump
I use 6-8 on the cover bolts and 35-40 on the pump to block mounting bolts. Others will have different opinions I'm sure.
gt350hr- Posts : 662
gt350hr wrote: I use 6-8 on the cover bolts and 35-40 on the pump to block mounting bolts. Others will have different opinions I'm sure.
That is as good as any for a general torque ... a lot will depend upon the fasteners used.
70shortbox wrote:With or without a gasket?
Does this OP have two identities here ...?
The gasket being there or not will not make any difference as to the amount of stretch of the fastener.
» 466 pump gas street engine HP/Torque results
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» smog pump for a vacum pump
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
