Dt9Z-6316-c damper?
Dt9Z-6316-c damper?
Is this part interchangeable and usable on a 71 429 check engine?
Pastel Blue- Posts : 47
Above post....
Should read cobra jet...
Re: Dt9Z-6316-c damper?
Should interchange fine, it's not the correct part but it will work
dtz9 damper
dfree383 wrote:Should interchange fine, it's not the correct part but it will work
What is the issue? Would not want to put something on an engine that is not the correct part. or, are you just saying that it is not the original C8 version? thanks
Yep it's not a CJ part it's a truck part
I have an extra CJ dampener if you need one.
69BOSS- Posts : 75
