GM Starter on Eliminator Block
+6
bigblock t-bird
hienergy557
taj362
10 posters
Okay, this one is a little in the weeds, bare with me.....
I plan on using a gm starter mounted on the drivers side of an eliminator block. The reason I want to do this is so that I can use a smaller diameter flywheel, and mount it inside a browell or trick titanium can. The stock type 184 tooth flywheel will not fit, as the diameter is too big. I understand that the flywheel and clutch will be a custom deal. I already spoke with RAM and they can put a bbf crank pattern in a 142 tooth flywheel for their full billet race clutches.
I am unsure of what to do about an oil pan, as most of the ford pans have a kick-out on the driver side that would most likely interfere with the drivers side starter. Any ideas on what pan may fit with a starter on the drivers side? this is going to be in your typical drag race prepped fox body.
Thanks,
Tom
Thanks,
Tom
taj362- Posts : 3
Re: GM Starter on Eliminator Block
There shouldn't be any kick out on the driver side of a pan. Any of the good pan manufacturers should be able to build you what you need. How much pan are you wanting? Wet sump, dry sump? How about the Ford M-6675-DRS460, Canton 15-770 or Moroso 20620? All seem to be "decent" pans.
Scott Foxwell- Posts : 419
Thanks, that makes me feel better about jumping into this.
The first iteration of this engine will probably be a wet-sump. As far as pan volume, I haven't got that far with my planning yet. The only piece of hardware I have for this so far is the transmission as that is what I am using behind a sbf that I am running now
Thanks,
Tom
Thanks,
Tom
taj362- Posts : 3
I always assumed the reason for moving the starter was to gain room for the full length kick out pans. I know some have done this and used the Chevy ring on a ford flywheel.
AS has been said ... most "kick-outs" up near the pan rail are on the passenger side, unless the engine is reverse rotation.
Full kick out down OUR drivers side(RH)
Standard size BBF flexplate and a 302-351C starter on a custom P/G adaptor plate.
hienergy557- Posts : 179
hienergy557 wrote:Full kick out down OUR drivers side(RH)
Yep. Some do have a full kick out even on driver side, just to increase the volume of the pan. Usually big, wet sump box pans. Not very typical, though.
Starter
Get up with KFM, he made my mid plate for a BBC 168 running a http://boninfanteracing.com/boninfante_high_performance_clutch.html 10" clutch. Do you have your bell housing yet? Steve
bigblock t-bird- Posts : 201
Bolting the starter on the block certainly does allow a better pan design but, the prime motive for moving the starter to the A96/Roberts block was not having to screw with the starter when the clutch was serviced between rounds.
Scott Foxwell wrote:hienergy557 wrote:Full kick out down OUR drivers side(RH)
When he says "drivers" side he means the right side of the engine because they are right hand drive in Australia.
DaveMcLain- Posts : 399
I don't consider it to be a kick out but, Charlie Gilbertson built me many pans that I call "driver's side flange in". Looks like this:
DaveMcLain wrote:Scott Foxwell wrote:hienergy557 wrote:Full kick out down OUR drivers side(RH)
Yep, RH drive.
I didn't want to have all the chevy fLIckheads telling me I need their parts to win. And I wouldn't mind a dollar for every race lost by a chevy starter.
We had Cleveland here from 1970 to 1984 so there's lots of them. I would have more chance of finding a 302-351 starter at the track than a BBF starter.
The pan has a full kick out down the RH side with a stepped bottom.
I'll try and post a picture from the RH side.
I can see what Lem is saying, If you had to pull the bellhousing to service the clutch you would want the starter mounted to the block.
Just a pity it would have to be a chevy one.
Proper Thinking
Hey Hienergy;
I like how you think on this subject.
DanE- Posts : 90
I'd get a mid plate made with the starter on the driver side. Keith Fulp can certainly do it.
jbozzelle- Posts : 3705
LOL...OK, NOW I see. (smacks forehead)...DaveMcLain wrote:Scott Foxwell wrote:hienergy557 wrote:Full kick out down OUR drivers side(RH)
» eliminator block
» wanted a460 block or eliminator block.
» wtb A460 block or Eliminator Block
» Eliminator Block
» amount of time it takes to get eliminator block?
» Eliminator Block
