Main bearings 1/2 groove or 3/4 groove
Main bearings 1/2 groove or 3/4 groove Empty Main bearings 1/2 groove or 3/4 groove
Post  Dave De August 26th 2016, 10:25 pm
Where have the 3/4 groove bearings gone? All I see are 1/2 groove.
Main bearings 1/2 groove or 3/4 groove Empty Re: Main bearings 1/2 groove or 3/4 groove
Post  Lem Evans August 27th 2016, 9:30 am
FM 134M were 3/4. Have they gone to 1/2?
Post  Dave De August 27th 2016, 10:18 pm
I posted too soon. This comes from re-ordering Clevite H series mains and they were 3/4 groove but now are 1/2 groove. For some reason I tend to stay away from Speed Pro and yes they are still 3/4 groove. Looking up King bearings the H series are 3/4 groove.
Do I need 3/4 groove?
Post  rmcomprandy August 27th 2016, 11:51 pm
That is all a personal decision ...
A full groove will help a deficiency in the rod bearing / journal union to be better but, a half groove, (actually 165 degree groove which nobody makes), will help the load carrying capability of the main bearing oil film.
A 3/4 groove was an attempt to get the best of both worlds. So, it really depends upon the actual working atmosphere of all the bearings and where you think needs the biggest "helping hand"..
Post  Dave De August 28th 2016, 7:01 am
rmcomprandy wrote:That is all a personal decision ...
Aren't 385 series engines more prone to rod bearing failure over main bearing? This would give the 3/4 groove more application? I am basing that on a failure of mine years ago with a D9 block. Now A460 block with priority main may not be an issue for me. Maybe this is a non-issue to get oil to the rod bearings 50% more time duration?
Post  rmcomprandy August 28th 2016, 11:02 am
The quality and strength of the parts, (including oil thickness and clearances), used in a rotating assembly will change the point of the "weak link" and what will be best for THAT situation.
The only way to actually know is to run it within the environment it will get used, take it apart and inspect the condition of everything and re-assemble it all accordingly.
Post  away September 7th 2016, 4:17 pm
Run FULL GROOVE period. Protect them rods!! I run full groove in all my stuff and just went 5.53 @124 in the heat this past weekend!
Adrian
away
away
Post  Carl September 7th 2016, 5:24 pm
It doesn't make a big difference in most applications.
I run half groove, and went 150.7 mph in the standing mile last weekend.
Carl
Post  AZFairlane September 7th 2016, 8:48 pm
Way to go Carl, is that the first time over 150mph?
AZFairlane
AZFairlane
Post  Carl September 11th 2016, 8:35 am
AZFairlane wrote:Way to go Carl, is that the first time over 150mph?
Thanks. It's a new personal best. The land speed guys call it "the 150 club".
Carl
