Cam bolt...
Cam bolt...
I have an arp cam bolt ...putting together seems its 1/2 to long ?
Using a comp timing chain set
Not sure if I got wrong one but arp 255-1001
I have stock one but not sure if it will be fine ? 600 hp give or take solid lifter cam
Had a shitty week one of my in laws found out terminal cancer, putting engine together these small fits that are slowing me upĀ
5pointslow- Posts : 1408
Re: Cam bolt...
That bolt is probably made to be used with the fuel pump eccentric in place. A good Grade 8 bolt will work. You got the thick washer on there too?
jbozzelle- Posts : 3705
Re: Cam bolt...
Yes to the washer
Re: Cam bolt...
Either cut it or trip to the hardware store...
Re: Cam bolt...
WoW ... a 1/2" inch to long ... you probably have the wrong bolt.
The ARP 3/8 x16 threaded cam bolts I have here have got a 12 point 5/8" head and are 1 1/2" long under-head length.
» Best 4-Bolt caps/DOVE-A 2 Bolt
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» Rod bolt and cam bolt torque?
» 460 Cam bolt
» Reconditioned Rods - is this one ok?
» 460 Cam bolt
