445 fe stroker kits
445 fe stroker kits Empty 445 fe stroker kits
Post  66prostreetfairlane September 22nd 2016, 4:09 pm
Guy I am looking at picking a family friends 62 F100 show truck. It's currently got a built 428cj in it he is keeping. I'm looking at a 428 or 410 to replace it until today when stumbled on the 445ci stroker kits for the 390 blocks. I'm looking at the bottom end kit that has scat crank, scar I beam rods, and diamond pistons for $2300. The top end I'm looking at the Edelbrock power package 2044 that summit has. It includes heads, intake, cam, timing chain, gasket set, and bolts for $2650.
The intended use is street with Friday drives and car shows. The truck is likely pushing 3500lbs with a full custom oak bed, c6 trans, 3200 stall, not sure on gear. Will this setup work well on the street, give good low end torque, and a lumpy idle?
Side note if one of the guys on the board can get this stuff as a dealer I will order through one of you.
66prostreetfairlane
66prostreetfairlane
https://www.reiautomationsquad.com/
445 fe stroker kits Empty Re: 445 fe stroker kits
Post  dfree383 September 22nd 2016, 5:50 pm
I have a complete 475 hp 428 that's brand new for sale
Post  66prostreetfairlane September 22nd 2016, 6:07 pm
I sent you a PM dfree383
66prostreetfairlane
66prostreetfairlane
Post  DeepRoots September 23rd 2016, 12:34 pm
445 kits are awesome. I have one I put in my 63.5 Galaxie.
Still, a total build is expensive. I've heard too many bad things about all the Fe stroker kits except Scat, so that is what I used.
Great way to take a 360 block and add some cubic inches.
I suspect buying Dfree's 428 would be cheaper and obviously easier.
DeepRoots
Post  66prostreetfairlane September 24th 2016, 12:43 am
Well we found an old picture of the truck for those wondering. It had flames put on the front of it after this picture, they are silver from the front into a yellow orange.
445 fe stroker kits 20160910
66prostreetfairlane
66prostreetfairlane
445 fe stroker kits Empty Survival motorsports
Post  manofmerc September 26th 2016, 4:56 am
Survival motorsports has the best pricing and 445 experience .They have a very informative web site with pricing and engine builds .The ford fe forum has lots of good information as well.Good luck with your build .Doug
manofmerc
