Headers or not?
Headers or not? Empty Headers or not?
Post  RayDav October 3rd 2016, 11:21 am
I am currently putting together a 460 with a 4.50 inch crank.  It is going into a 55 Ford wagon set up as a tow vehicle.  I doubt it will see 5K RPM.
Stock exhaust manifolds can fit.  I have built headers before and can do it again.  But it is a lot of work.  Is there any point in headers for this application?
TY
Ray
RayDav
Headers or not? Empty Re: Headers or not?
Post  IDT-572 October 3rd 2016, 12:39 pm
Stock manifolds will hurt it at even that low rpm. Maybe truck manifolds would be something to look at. Made sort of like the old rams horn Chevy's but better.
Post  RayDav October 3rd 2016, 3:41 pm
IDT-572 wrote:Made sort of like the old rams horn
 There are something similar to rams horn readily available.  They are down the middle, right at the motor mounts.  I need something like the original 55 manifolds; up, over, and down the back.
So, moving along a bit, how about a tri-Y?  Whatever the port size is, to a 2.0 inch Y, then to a 2.5 Y which is the size of rest of the system.
RayDav
Post  rmk57 October 3rd 2016, 4:13 pm
FPA makes header for your application. Biggest obstacle with your header swap would be the steering box. Maybe modify a pair of cheap shorties.
rmk57
Post  RayDav October 3rd 2016, 4:26 pm
rmk57 wrote:FPA makes header for your application. Biggest obstacle with your header swap would be the steering box. Maybe modify a pair of cheap shorties.
I have been to the FPA site, never found a picture.
And I now only do exhaust in stainless.
I have considered cheap shorties and reducing them to flange and stubs. Forming to a non-round flange opening, without a same-shape mandrel is the hard part.
I have a front sump pan and rear, center steer rack. There is a lot of room at the rear, but I need to clear the upper control arms.
I have pics but this forum says I cannot post a link for a week.
RayDav
Post  dfree383 October 3rd 2016, 5:22 pm
Street rod shortys would be a good option and cost effective.
The manifolds are going to kill it.
Post  61coon October 3rd 2016, 5:57 pm
dfree383 wrote:Street rod shortys would be a good option and cost effective.
^^^ This! Sanderson makes a nice set. Under $400 iirc
61coon
61coon
Post  RayDav October 4th 2016, 10:53 am
Both sides need to be like the right side of the FF462 set, and stainless.  And that seems to mean do them myself.
Again, what about tri-Y?
RayDav
Post  RayDav October 4th 2016, 11:30 am
There is one set that would work.
stainlessworks SKU: BBFT
Ford Big Block Turbo Headers: Up and Forward
I have an 89 7.3 IDI in a 9K#, 84, E350. I added a 2000, 7.3 PSD turbo, remote. Five pounds makes a huge difference.
I have a pair of T3/T4 that I was going to use but could not find room for the passenger side, so went with a single, larger, remote.
And there they sit on the shelf and the only headers I find are for twin turbos. Is fate plotting something here?
RayDav
