Small block E40D to 460 BBF
I have a 95 Bronco that I have had for 10 years. Last year I had the tranny (e40d) totally rebuilt for HP use. Since then it hasn't gone 100 miles. The truck is now in the body shop for a frame of custom restoration. I always wanted to drop in a bigger engine. I was given a 460EFI off a Motor Home that I plan to bore and stroke to get 600 to 700 HP. My problem is that my newly rebuilt tranny is off a 5.0L small block that wont bolt up to the 460 BB. I know they make the E4OD for both SB and BB. Can I get an E4OD from a 460 and use the parts from the small block E4OD, it has a ton of new parts, and I hate to have to build a new one for the 460.
466 bronco- Posts : 5
Re: Small block E40D to 460 BBF
466 bronco wrote:I have a 95 Bronco that I have had for 10 years. Last year I had the tranny (e40d) totally rebuilt for HP use. Since then it hasn't gone 100 miles. The truck is now in the body shop for a frame of custom restoration. I always wanted to drop in a bigger engine. I was given a 460EFI off a Motor Home that I plan to bore and stroke to get 600 to 700 HP. My problem is that my newly rebuilt tranny is off a 5.0L small block that wont bolt up to the 460 BB. I know they make the E4OD for both SB and BB. Can I get an E4OD from a 460 and use the parts from the small block E4OD, it has a ton of new parts, and I hate to have to build a new one for the 460.
Yes you can . Call whatever it take transmission parts and order you a case for a 460 the same year as your sbf case and swap all of your parts to it. Good luck
whitefield- Posts : 2244
Thank you for the info. I will take that route. Not giving up on the BBF
» New 57 Ford Project Should we go big block or small block? Pics added
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» distributer block hole is too small on an A460 block
» small block BLOCK choices
» Need a C4 for a small block
