9 inch 3rd member caltracs mono leaf springs headers
9 inch 3rd member caltracs mono leaf springs headers Empty 9 inch 3rd member caltracs mono leaf springs headers
Post  70429scj October 31st 2016, 12:35 pm
all parts are in ar with zip of 72801 will post pictures as soon as they are pulled from the car probably tomorrow thanks steve
calvert 2000 split mono leaf springs. complete with aluminum bushings in front eyes, & urethane bushings in rear eyes, Substantially lighter than multileaf springs for unsprung weight savings. Heavy duty alignment spring clamps. $398.00
[attachment=0]products-splitmono1[1].jpg[/attachment]
CalTracs 6520 Drag Profile 2 Hole Complete bolt-on, no cutting, welding, or modifications to OEM suspension. Keeps axle from rotating, helping maintain pinion angle.
Improves 60ft times. Full preload adjustability. Eliminates spring wrap-up. powdercoated gloss black finish.PSCA, NMCA, NHRA approved. $339.00
[attachment=1]41.jpg[/attachment]
these are on my 70 torino and the caltrac bars will bolt on and work on other fords with leaf springs. the spring should also bolt on to other fords. these springs out of the box retained the ride height I had using a set of springs I ah bought from st Louis spring company and they were ordered for stock ride height. this car is a street driven car and has been put in the daily drive slot when need be without touching anything. if your looking for added traction without having to change from the stock wheels and tires and keeping they way the car looked from the factory or cutting up your car this setup is pretty amazing. my car has constantly changed in different motor combo's 400-650 hp, I have used many different tire sizes, stock tires to the latest in m/t drag radials and the best thing was you adjusted the bars to change the preload and off you go. I knew I had done the right thing after bolting this setup on went to the track and the track owner himself along with a few other inquiring minds wanted to know what I had done to the motor because the car was now picking the front wheels up and this was with a maybe 500hp motor.
9 inch 3rd member strange nodular housing N1905 $329.97 Strange Daytona-Style Pinion Supports N1914 $105.97 Strange Chromoly Pinion Yokes U1603 $129.97 Strange U-Joint Girdles U1610HD $87.97 Eaton Detroit Lockers 187SL17B $525.97 ring& pinion 07890457 $219.97 Richmond Gear 83-1003-1 $117.97 these are the parts that were used to build this 3rd member I was planning on using it with a 800hp-c6-4700 stall and 4,57 with m/t pro drag radials and be street and strip friendly and as indestructible as I could get used very very little behind my 466 -650hp with no strip passes going back to a all stock setup for the wife and grandkids to take to the car shows and long sunday drives to get them interested in cars already have a pretty dedecated strip car for paw paw' s sunday drives and it's got a 8.8 so don't need this 3rd member 1,500.00 was the original cost
I will also have in the near future from the same car a set of hooker 6115 headers that were jet hot coated when new i don t want to put a price on them until there out of the car and i can be 100% sure there are no dents or drag marks on them. $250 for springs $225 for the caltrack bars 850.00 for the 3rd member i will post pictures as soon as possible probably monday when i remove it from the car.
70429scj
70429scj
9 inch 3rd member caltracs mono leaf springs headers Empty Re: 9 inch 3rd member caltracs mono leaf springs headers
Post  SLord82 October 31st 2016, 4:14 pm
edit - double post
SLord82
Post  SLord82 October 31st 2016, 4:15 pm
Caltrac lists a bunch of axle and shock location options for the traction bars. What axle and shock location are they set for?
Any idea what rate the springs are? Whats the distance from the axle center to the fender lip when the car is sitting on them?
SLord82
9 inch 3rd member caltracs mono leaf springs headers Empty Info
Post  70429scj October 31st 2016, 7:13 pm
9 inch housing stock shock location I will check but I believe both are in the rear. with 295/55/15 tires I think it's 13 1/2 inches from the center of the axle to the lip of the fender. Spring rate from Caltrac was stock rate and ride height for a 70 Torino forgot to add that I also have the rancho 9 way adjustable shocks 31 spline small bearing axles aftermarket and complete rear big drum brakes with e brake cables new wheel cylinders brake shoes and hardware kits pictures to come tommorow
70429scj
70429scj
Post  SLord82 October 31st 2016, 10:46 pm
Ford offered a few different springs for the Torino rear end. A regular spring and then the cobra/competition spring which was thicker and slightly lower and then a heavy duty spring which was similar to the cobra spring but with a slightly higher rate.
SLord82
Post  70429scj October 31st 2016, 11:14 pm
When you order the springs it simply states stock or + or- from stock or custom and I ordered stock height I will call tommorow and ask which spring rate is used for the stock ride height.
70429scj
70429scj
Post  BBFTorino November 1st 2016, 12:27 am
And ranchero springs are longer than Torino/Fairlane passenger cars.
Post  Plowboy November 1st 2016, 9:23 am
Is the third member for 31 spine axles? And what price are you asking?
Plowboy
Post  70429scj November 1st 2016, 11:28 am
3rd member is 31 spline and price is 850
70429scj
70429scj
Post  Plowboy November 1st 2016, 12:42 pm
Ok I would have interest in it. Give me a call 7854791231 if you don't mind.
Plowboy
Post  SLord82 November 1st 2016, 3:36 pm
70429scj wrote:When you order the springs it simply states stock or + or- from stock or custom and I ordered stock height I will call tommorow and ask which spring rate is used for the stock ride height.
Ok, let me know what they say. I'll be interested in them if they are similar to the cobra or HD springs. I'll also be interested in the caltracs to go with them.
SLord82
9 inch 3rd member caltracs mono leaf springs headers Empty sold
Post  70429scj November 3rd 2016, 12:51 am
Mono springs , caltracs ,3rd member all sold will update header axles and shocks with pictures shortly thanks to the forum
70429scj
70429scj
