forged pistons timing chain oil pump rods roller rockers
forged pistons timing chain oil pump rods roller rockers Empty forged pistons timing chain oil pump rods roller rockers
Post  70429scj November 4th 2016, 5:09 pm
Building a budget 460 so used parts are not a problem because this is a temporary build to keep it running and moving.
Would like standerad bore forged or .030 stock vavle layout
Rods scj eagle i beam or factory with upgraded bolts
Double roller timing chain old style straight up
Roller rockers
Cam and lifters
Oil pump front sump
Aluminum intake dual plane the uglier the better
Cast aluminum valve covers
Rebuildable 750 -850 vacum secondary
NEED SECONDARY METERING BLOCK FOR 3310 CONVERSION IM DOING NOW
valves 2.19 & 1.72
Would condsider a set of used procom heads
Exhaust manifolds mid 70s or somones old short tube headers i can modify
Used is just fine with me
70429scj
70429scj
