timing chain oil pump rods roller rockers
jeffgfg
bradsc1954
knrclark
70429scj
 timing chain oil pump rods roller rockers Empty timing chain oil pump rods roller rockers
Post  70429scj November 5th 2016, 3:21 am
Building a budget 460 so used parts are not a problem because this is a temporary build to keep it running and moving
Rods scj eagle i beam or factory with upgraded bolts
Double roller timing chain old style straight up
Roller rockers
Cam and lifters
Oil pump front sump
Aluminum intake dual plane the uglier the better
Cast aluminum valve covers
Rebuildable 750 -850 vacum secondary
NEED SECONDARY METERING BLOCK FOR 3310 CONVERSION IM DOING NOW
valves 2.19 & 1.72
Would condsider a set of used procom heads
Exhaust manifolds mid 70s or somones old short tube headers i can modify
Used is just fine with me
If somebody has a set of used forged pistions for stock or 0.030 bore im interested stock valve layout
Thanks steve
70429scj
70429scj
 timing chain oil pump rods roller rockers Empty dbl post
Post  70429scj November 5th 2016, 3:34 am
Db post and i have no idea how!
70429scj
70429scj
 timing chain oil pump rods roller rockers Empty Re: timing chain oil pump rods roller rockers
Post  knrclark November 6th 2016, 12:36 pm
Steve,
I have an intake Victor, oil pump HV and timing chain.
Kerry
knrclark
knrclark
Post  bradsc1954 November 6th 2016, 6:59 pm
I have a brand new set of Lunati solid lifter and have a set push rods. I think I also have a couple valves.
bradsc1954
Post  jeffgfg November 6th 2016, 8:17 pm
I believe I have a set of flat top pistons on SCJ rods supposed to have only dnyo time on them. I will have to check and see if they are forged. If interested.
jeffgfg
Post  gt350hr November 8th 2016, 1:30 pm
I have a set of used H/S roller rockers.
gt350hr
Post  bluef100fe November 14th 2016, 3:15 pm
I have a set of used eagle SIR rods, they need resizing and new bushings... $140 plus shipping
bluef100fe
bluef100fe
 timing chain oil pump rods roller rockers Empty Used Cast Valve Covers
Post  clevelandcoupe January 23rd 2017, 7:15 pm
Sir,
I don't know if you ever found a set of factory cast alum valve covers, if not I have a set for you !!!
They are factory 429 ribbed as used on the Torinos & mustangs in 70 & 71. The are not perfect, have been repaired and could need more repairs. I picked them up at a swap meet and did not use. I will sell for $125.00 plus the ride.
Let me know if you're interested.
Text me at (201)852-4267
Thanks, Jay
clevelandcoupe
Post  fordmonsta January 23rd 2017, 7:35 pm
I've got a set of rockers they are cam motion 1.73
fordmonsta
