Disaster . Three leg engine stands suck
+6
Gregaust
10.0
1EFF100
cobra501
10 posters
Just happened. Engine went over on three leg stand. Crank broke , timing cover broke and oilpump . Pride chaddered . Major blow to the F100 project. All cast stock stuff but it still hurts .
cobra501- Posts : 95
Re: Disaster . Three leg engine stands suck
Oh man, that sucks. Sorry to hear it.
1EFF100- Posts : 265
They are scary with a Big Block on them. Glad no one was hurt.
supervel45- Posts : 4498
Where are you at, I have a crank and oil pump(for rear sump) that you can have but shipping will be a killer on the crank.
FalconEh- Posts : 1448
I'm in Mobile Alabama. I'm looking to replace the parts soon. Thinks I need. Crank stock stroke , timing cover , front sump oil pump. Also need a crank spacer and dust shield on the back side. Never had these to begin with. Nothing else was hurt . Despite the accident I installed the engine in the truck anyway to check fit . This is a custom build with a tube chassie. Header on left hitting so far. I will have to remove the collector and reclock it inwards. Thanks for the offer but I don't think you are on the same piece of dirt as me. lol
cobra501 wrote:I'm in Mobile Alabama. I'm looking to replace the parts soon. Thinks I need. Crank stock stroke , timing cover , front sump oil pump. Also need a crank spacer and dust shield on the back side. Never had these to begin with. Nothing else was hurt . Despite the accident I installed the engine in the truck anyway to check fit . This is a custom build with a tube chassie. Header on left hitting so far. I will have to remove the collector and reclock it inwards. Thanks for the offer but I don't think you are on the same piece of dirt as me. lol
You are right, we are on a different piece of dirt, I am sure the other stroker guys in your area have some good stock cranks lying around...Good job with installing it anyways knowing it needs to come out, get the flat bar or angle iron out, drill a hole, add a bolt, and put a tip over bar on the front of that stand.
The 580 is on my good four leg stand. This stand will probably get pushed to the road. I'm gonna order another stand. Timing cover and dust shield is on order so far. I will recover.
Did that same thing years ago with a BB Chev and 3 legged engine stand, luckily it was just a chev!
Welded a piece of square tubing across the third leg and added 2 more casters, never happened again.
10.0- Posts : 54
10.0 wrote:Did that same thing years ago with a BB Chev and 3 legged engine stand, luckily it was just a chev!
Looks like we all been there . I had the same years ago , luckily was just an old clevo i was stripping for parts . I don't use 3 wheel stands any more . Great post to get it out there for other guys
Gregaust- Posts : 625
Been there. Didn't hurt the motor, but carved a big gash in the side of my new job trailer
fastashley- Posts : 70
I've never had that happen and we've got a few of the three wheel ones around the shop. With that said I don't push my luck and only use the little three wheeled ones on smaller engines. Thinking back about 20 years ago I was helping a friend who was building a 440 Chrysler degree in his cam. He had the engine on one of those cheap-O three wheel light weight stands and I noticed that he had welded a piece of angle iron between the upright and the bottom leg. He said that when he was putting the engine together he started to notice that every time he added another piece to the engine the stand sagged lower and lower so he jacked it up again and added the brace.
DaveMcLain- Posts : 399
Mike Stevens has several of the best engine stands I have ever seen. I've forgotten who he said built them but they are heavy duty. Maybe he'll see this and chime in with info and photos. Wish I had a half dozen of them.
The stands I have, were built by Jim Zale, anAustralian friend of my Dad's..
He use to sell them at the Long Beach swap meet in SoCal...
As Doug said, these things are heavy duty
One is even a fire up stand for running engines before they are installed..
QtrWarrior- Posts : 2702
» Need 66 to 69 falcon engine stands
» 1994 Ford F150 2WD 460 engine stands
» this would suck!
» Some UPS Drivers SUCK
» bbf motor stands
» this would suck!
» bbf motor stands
