1994 Ford F150 2WD 460 engine stands
1994 Ford F150 2WD 460 engine stands Empty 1994 Ford F150 2WD 460 engine stands
Post  69F100 May 11th 2015, 11:26 pm
I got a friend looking for some engine stands he putting a 460 in a 94 F150 he hadn't had any luck finding any at the local junk yards.
1994 Ford F150 2WD 460 engine stands Empty Re: 1994 Ford F150 2WD 460 engine stands
Post  HorsinAround May 12th 2015, 4:40 pm
Are you referring to the frame mounts?
http://www.frontpagefab.com
Post  69F100 May 12th 2015, 4:43 pm
Yes the frame mounts
Post  HorsinAround May 12th 2015, 9:31 pm
Of the 2 I have the one that is still pretty easy to get. You are welcome to it. The other side is harder to come by, mainly because it is riveted in. I'll ask around and see if I can find one.
Post  69F100 May 12th 2015, 11:14 pm
HorsinAround wrote:Of the 2 I have the one that is still pretty easy to get. You are welcome to it. The other side is harder to come by, mainly because it is riveted in. I'll ask around and see if I can find one.
OK I will let him know he building a street truck the engine he got out of a motorhome with not many miles on it. After he gets it all together and drives it a little we going to put a set of c9 heads or the dove-a heads I have on it, a small cam in it, and intake.
Post  Copperhead May 13th 2015, 8:41 am
I've got a set,......BUT,.... they came out of a 94 F-150 that had a 351w in it.    You can use them,.....but you would have to use the conversion motor mounts from L&L Products in order to make everything work.
If you're interested, just let me know.
Copperhead
Copperhead
Post  HorsinAround May 13th 2015, 10:53 am
I checked in the shop and I do still have the long bracket. I also called a yard where I get some of my stuff, and struck out. There are a couple other yards I have gotten parts before, but they are 3 hours away from me. Has he tried doing a google search? Also, he might try posting on Reddog's pulling forum, and there is also a couple face book forums as well that he could inquire on.(Ford 429 460) and 429/460 Big Block Fords)
Post  69F100 May 13th 2015, 12:39 pm
he going to a big swap meet Saturday to see what he can find any.
Post  lghting94 May 13th 2015, 1:28 pm
I think I still have a set but I probably gave to much for them when I got them. I have $100 in the pair
lghting94
lghting94
Post  HorsinAround May 13th 2015, 1:57 pm
That's not too terrible, The right side is readily available even through LMC truck. but the short left side is not. I supposed because Ford chose to rivet/bolt that side in place. Not sure why it's not available through LMC or NPD or something. Once I switch the rod over to front and mid plates only, I'll have both pieces as extra, but may decide to hang onto them since they are sort of hard to come by..
I'll give you the one I have, just send me a few bucks for shipping.
Post  69F100 May 13th 2015, 11:39 pm
lghting94 wrote:I think I still have a set but I probably gave to much for them when I got them.  I have $100 in the pair
Do you want to get rid of them if so how much he said he is interested if you want to get rid of them. If so pm me your number and I have him call you.
Post  lghting94 May 14th 2015, 8:29 am
Let me try to find them this weekend and I will let you know if I find them just want my money back and shipping cost
lghting94
lghting94
Post  69F100 May 14th 2015, 9:00 am
OK I let him know tonight at work.
Post  69F100 May 31st 2015, 9:23 am
bump still looking for a set
Post  lghting94 June 1st 2015, 8:32 am
Sorry I couldn't find them!
lghting94
lghting94
