1994 F250 Engine Question
I have a friend with a 94 F250 with a fuel injected 460. Runs great until you hook a trailer up, then it is a complete dog.
Any ideas?
Any ideas?
bronco911- Posts : 103
Re: 1994 F250 Engine Question
That leaves a lot of questions unanswered. Everything can be a dog if you hook up enough trailer.
What trailer, how heavy? What gears in the truck? Big tires? Pulling long hills? Truck plain worn out?, etc., etc., etc.,......
maverick- BBF CONTRIBUTOR
Sorry for leaving out some details, was rushing it while fueling up with him on the phone. It has a newly rebuilt motor, 4:10 gearing, super cab long box. Any trailer over 18' makes it fall on it's face even with a light load. A 1/2 ton chevy with a 350 can pull the same trailer he hauls and you can barely tell it is there, but the 460 just acts like it has a house behind it. He has had the trans and converter replaced, put an rv cam in and still no power. But with nothing hooked to it the truck screams.maverick wrote:That leaves a lot of questions unanswered. Everything can be a dog if you hook up enough trailer.
He is at a loss and ready to switch to a diesel.
He has owned this truck since brand new, and it has always been this way, but now he is using it for longer hauls so it has become a major issue.
Thanks, Ray
bronco911 wrote:Sorry for leaving out some details, was rushing it while fueling up with him on the phone. It has a newly rebuilt motor, 4:10 gearing, super cab long box. Any trailer over 18' makes it fall on it's face even with a light load. A 1/2 ton chevy with a 350 can pull the same trailer he hauls and you can barely tell it is there, but the 460 just acts like it has a house behind it. He has had the trans and converter replaced, put an rv cam in and still no power. But with nothing hooked to it the truck screams.maverick wrote:That leaves a lot of questions unanswered. Everything can be a dog if you hook up enough trailer.
Thanks, Ray
If it has been this way since new ,I would look at the computer tune ! Exhaust and fuel psi would be the next along with the distributor . Seen the distributors in those thing act funny and do strange things. Does it have check engine light on or any other symptoms ?
whitefield- Posts : 2244
Nope, no light or other symptoms. New duel exhaust. I think they checked the fuel PSI, but I will mention that and the distributor to him. As far as the tune goes, you think maybe an aftermarket tuner would be worth a try, or just dealer confirming the stock tune is correct?
Thanks for the input!!!
Ray
Ray
Confirm tune is correct first , then if it isn't fix that first then put a tuner on it. Even if it is ok there is still something wrong with the power out put!bronco911 wrote:Nope, no light or other symptoms. New duel exhaust. I think they checked the fuel PSI, but I will mention that and the distributor to him. As far as the tune goes, you think maybe an aftermarket tuner would be worth a try, or just dealer confirming the stock tune is correct?
Ray
when the new cam was installed , did a new timeing set go in with it ? was it a multi index crank gear ? Worked on a 440 Had the same problem , unloaded was good, loaded a pig, crank gear had 3 marks,, guy said they set it straight up, the marks were a , 0 and a , o,, once set to 0 zero, he was all goodbronco911 wrote:Sorry for leaving out some details, was rushing it while fueling up with him on the phone. It has a newly rebuilt motor, 4:10 gearing, super cab long box. Any trailer over 18' makes it fall on it's face even with a light load. A 1/2 ton chevy with a 350 can pull the same trailer he hauls and you can barely tell it is there, but the 460 just acts like it has a house behind it. He has had the trans and converter replaced, put an rv cam in and still no power. But with nothing hooked to it the truck screams.maverick wrote:That leaves a lot of questions unanswered. Everything can be a dog if you hook up enough trailer.
Thanks, Ray
samiam- Posts : 240
» 1994 351w f150 engine
» 429 Engine build help? 75 Supercab f250 short bed.
» F250 460 Starter question extra wire
» 460 lincoln engine into 85 f250
» F250 rear bumper question
