460 lincoln engine into 85 f250
460 lincoln engine into 85 f250 Empty 460 lincoln engine into 85 f250
Post  strick November 24th 2013, 1:43 pm
Engine is out of 70's Lincoln (supposedly) put into 85 f250. Has 184 tooth flywheel 460 starter. Starts but breaks starter nose while running.
strick
460 lincoln engine into 85 f250 Empty Re: 460 lincoln engine into 85 f250
Post  samiam November 25th 2013, 1:33 am
460 starters are different for auto vs manual,, here is the article, maybe it will help....
http://www.ford-trucks.com/forums/1133132-1984-f250-stakebody-460-starter-issues.html
samiam
samiam
Post  TravisRice December 6th 2013, 11:16 pm
strick wrote:Engine is out of 70's Lincoln (supposedly) put into 85 f250. Has 184 tooth flywheel 460 starter. Starts but breaks starter nose while running.
You say flywheel so I am thinking its a manual trans .......... Pretty sure you have to use the 85 flywheel and knock the weights off of it .......... 0 Balance. There is a thickness difference in the flywheels from old to newer style and that may be your problem.
