water pump issue bolt length mezierre
water pump issue bolt length mezierre  Empty water pump issue bolt length mezierre
Post  5pointslow November 15th 2016, 6:34 am
well im having an issue
my last thing im doing to engine before bringing to dyno on Saturday morning is to put the water pump on
I put backing plate on and then the pump , the stainless allen cap bolts are 4 inches long and all four of them come up to long by 1/4-3/8 of an inch to long and stop if i go more they feel like they will break . not sure if any of you guys have had this issue and it gets me there all exactly the same
im bringing a tap extension home today from work with a new tap and see if holes in block are not clean , the machine shop who did my machine work said they re chased all threads when cleaning block
5pointslow
5pointslow
water pump issue bolt length mezierre  Empty Re: water pump issue bolt length mezierre
Post  maverick November 15th 2016, 8:57 am
Shorten the bolts?
Post  D. Sea November 15th 2016, 9:01 am
If you're planning on using an engine plate then they are the correct lenght Wink
D. Sea
D. Sea
Post  5pointslow November 15th 2016, 9:14 am
D. Sea wrote:If you're planning on using an engine plate then they are the correct lenght Wink
im not using an engine plate
5pointslow
5pointslow
Post  5pointslow November 15th 2016, 9:15 am
maverick wrote:Shorten the bolts?
this is what im going to be doing , but was not sure if anyone else had this issue
5pointslow
5pointslow
Post  5pointslow November 15th 2016, 9:52 am
i see on there site they sell spacers ....maybe thats what i needed all along and did not know
5pointslow
5pointslow
