Rust on the plugs, moisture in the cylinders
Greg_P
Tearing down the 545, and seeing this problem again. This engine has always seemed to gather moisture/condensation/water or whatever it is in the cylinders. Just enough to put a little surfce rust on the plugs, and maybe make some superficial marks on the cylinders.
There are zero indications of head gasket leakage, the water in the radiator never goes down (I run a little antifreeze, too, and I don't detect that in the cyls, but anything is possible).
I have run three different blocks as well, and the problem was unchanged.
Does anyone have any ideas on what I can do to stop this issue?
Thanks,
Greg
Thanks,
Greg
Greg_P- Posts : 1009
Re: Rust on the plugs, moisture in the cylinders
i had surface rust on the NGK ......... switched to Autolite AR never again !!!
The oil is never anything but super clean.
Is there anything I can do to minimize this?
Thanks,
Greg
Thanks,
Greg
It's the plating the AR series have .bruno wrote:i had surface rust on the NGK ......... switched to Autolite AR never again !!!
Relative to the cyl walls...a guy could spray WD 40 in the plug holes and close the valves during the off season .Greg_P wrote:The oil is never anything but super clean.
Thanks,
Greg
You could pull the plugs and spray the cylinders down with WD40 or something similar when it's going to be parked for extended periods. Won't cure the problem, but it will help minimize the rust.
Nevs- BBF CONTRIBUTOR
Damn, Lem, you beat me to it
Nevs wrote:Damn, Lem, you beat me to it
Thats why he's tha Man..
res0rli9- BBF CONTRIBUTOR
Nobody types slower than I.......he must have started latterres0rli9 wrote:Nevs wrote:Damn, Lem, you beat me to it
Nobody types slower than I.......he must have started latter [/quote]
I beg to differ
I beg to differ
I get loads of moisture in my cyls from the alky, I pull them after every race after i fog the motor down, no rust, leakdown numbers good. Might be a tad harder to do that on your deal Greg, after you get done racing and put the car up pull the cleaner and spray some WD down each carb barrel with the eng idling............easy to do.
I think it has a lot to do with where you keep it. Mine will sweat when the temp. and humidity are right in the shop! Sometimes I can see a condensation line on the fuel cell, carb ect.... But it's only in the winter monthsGreg_P wrote:The oil is never anything but super clean.
Thanks,
Greg
dirtbogger- Posts : 172
» moisture accumulation under valve covers?
» lean cylinders?
» Engine Misfire on Cylinders 1,4,5,8
» Center cylinders lean question.
» Is This Cam Salvageable? -- Rust
» lean cylinders?
