Is This Cam Salvageable? -- Rust
Hey guys. I pulled this cam from one of my parts engines years ago and it has been sitting in storage since. Unfortunately, I live in a damp climate only a few miles from the Pacific Ocean and this happens frequently with any unprotected bare metal. I was careless in this instance...
Do you guys think with a little elbow grease this camshaft can be serviceable once again? Or is it toast?
It's an old Crane HMV-260-2. I think it may work well in my fuel efficient 460 build.
Trying to keep the build as budget oriented as possible and use as many parts I already have.
Thanks.
https://photos.smugmug.com/My-First-Gallery/i-kF8WFrL/0/3ad01848/X2/DSC00682-X2.jpg
https://photos.smugmug.com/My-First-Gallery/i-5RzM28Z/0/18babe9b/M/DSC00683-M.jpg
https://photos.smugmug.com/My-First-Gallery/i-CqVWrHT/0/f4a785b4/M/DSC00685-M.jpg
https://photos.smugmug.com/My-First-Gallery/i-sH4dqwx/0/70e03cf1/X2/DSC00684-X2.jpg
https://photos.smugmug.com/My-First-Gallery/i-jjmkpMx/0/565aee87/X2/DSC00687-X2.jpg
https://photos.smugmug.com/My-First-Gallery/i-dWM4GGP/0/fd1f0394/M/DSC00686-M.jpg
https://photos.smugmug.com/My-First-Gallery/i-sbMtFNP/0/08a9e5fb/M/DSC00688-M.jpg
https://brucejessie.smugmug.com/My-First-Gallery/i-7mXKPtx
Thanks.
1EFF100- Posts : 265
Re: Is This Cam Salvageable? -- Rust
I can't say one way or the other if it's salvageable, but for future storage of parts try this out. Works great. https://www.crcindustries.com/products/sp-400-8482-corrosion-inhibitor-10-wt-oz-03282.html I should also add they make this for primarily for indoor use. https://www.crcindustries.com/products/sp-350-8482-corrosion-inhibitor-11-wt-oz-03262.html
Doug Rahn wrote:I can't say one way or the other if it's salvageable, but for future storage of parts try this out. Works great. https://www.crcindustries.com/products/sp-400-8482-corrosion-inhibitor-10-wt-oz-03282.html I should also add they make this for primarily for indoor use. https://www.crcindustries.com/products/sp-350-8482-corrosion-inhibitor-11-wt-oz-03262.html
Thanks, Doug. Will be using that in the future.
Those pics look like you could polish it up and use it. Use a zinc additive for break in like with a new one. I have a crankshaft polisher that I could use in a case like this myself.
away- Posts : 266
Yes, you can generally clean off rust from cam. However, after cleaning it off make sure that all of the cam lobes sizes are within acceptable tolerances. May need to use oversized cam bearings to restore clearances. If you polish/clean it up make sure there are no pits at all. Another way is to take it to your local shop that has a cam grinder and have them restore it. They will grind the base circles smaller to maintain cam specs. They generally charge less then what it costs for a new camshaft. That answers the rust issues. However, you have 2 other issues with the cam that I noticed from the pics that make this cam a piece for the junk pile! #1 lobe is going flat and the distributor drive gear has chunks out of it on its leading edges.
jmarks99- Posts : 6
» Rust on machined surfaces
» How to remove rust from a gas tank?
» Rust on the plugs, moisture in the cylinders
» Light rust in lifter bores
» wanted 79 bronco rust free
