c6 torque converter 10 in
this is a jegs converter made by transmission specialties it is rated for 2900-3300 rpm. in my car with my combo it flashed around 46-4700 rpm according to the data log . that was behind a 521 in a 3900lb car with 3.89 gear.it has 4 passes on it and was made in june 2016 .i am going to get a ultimate built for my application. here is a link to the jegs site http://www.jegs.com/i/JEGS-Performance-Products/555/60464/10002/-1
and the info from the transmission specialties web site
All the 10" Street/Strip Converters are also offered in XHD (extra heavy duty) models. This adds anti-ballooning plates on the pump and cover side of the converter and is highly recommended for nitrous, blower, and transbrake applications or HP over 600. It is rated up to 850 HP.
Three new Torrington bearings
New impeller hub
New pilot
New turbine hub
Fully heli brazed fins
360 degree laser cut mounting ring with dual bolt pattern.
Computer balanced
High pressure leak test
Very competitive price
this cost $450 new,i am asking $350 shipped to the lower 48 states . item is in columbus ohio email 2big2go@msn.com
thanks , wayne
New impeller hub
New pilot
New turbine hub
Computer balanced
thanks , wayne
wayney- Posts : 187
» Torque converter
» torque converter
» mudracers and spragless ?
» 10" C6 torque converter
» Canton Pan, Motor Plate and Convertor
» torque converter
