New Edelbrock head
+10
Gary Blair
68galaxie
Carl
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
New Edelbrock head
I'm just going to leave these here.....
![New Edelbrock head 15350466_1215159428563220_6942987562323557803_n](https://scontent.fapa1-1.fna.fbcdn.net/v/t1.0-9/15350466_1215159428563220_6942987562323557803_n.jpg?oh=01016e9fa4165c9b951979b24c5a171a&oe=58B913F7)
![New Edelbrock head 15439955_1215159431896553_5031402815673829855_n](https://scontent.fapa1-1.fna.fbcdn.net/v/t1.0-9/15439955_1215159431896553_5031402815673829855_n.jpg?oh=eff62bb4458368acd1ab9b4550d8221c&oe=58FA8202)
![New Edelbrock head 15327490_1215159391896557_1235862971506477452_n](https://scontent.fapa1-1.fna.fbcdn.net/v/t1.0-9/15327490_1215159391896557_1235862971506477452_n.jpg?oh=f2071fde8895fcabe2d70694182c0494&oe=58F8810B)
![New Edelbrock head 15326434_1215159401896556_4742369527502232267_n](https://scontent.fapa1-1.fna.fbcdn.net/v/t1.0-9/15326434_1215159401896556_4742369527502232267_n.jpg?oh=76efdbae5a80d39148c25256b8dd543e&oe=58EFB363)
Carl- Posts : 284
Re: New Edelbrock head
Versions of that have seen around for awhile never seem to see any running or in any catalogs for sale
looks just like: http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/gm/bbc/bes-edelbrock-big-victor-3-heads
Did Edelbrock modify the BBC version to fit a BBF?
68galaxie- Posts : 351
dfree383 wrote:Versions of that have seen around for awhile never seem to see any running or in any catalogs for sale
There a PRI heads and those that can be delivered next week.
Lem Evans wrote:dfree383 wrote:Versions of that have seen around for awhile never seem to see any running or in any catalogs for sale
I'm supprised You don't see them on any Fords at the track
Are they missing some exhaust bolt holes, or is that what all the cool kids are doing now?????
![Embarassed](https://2img.net/i/fa/i/smiles/icon_redface.gif)
cletus66- Posts : 865
Apparently builders have been waiting years for the GM version to be released.
http://www.yellowbullet.com/forum/showthread.php?t=1169706&highlight=bv3
Thanks Carl, those look good. Now if they will just make them available.
68formalGT- Posts : 865
Yeah, like the AFR heads.
Wasn't long ago everyone was calling them vapor-ware too.
Carl- Posts : 284
dfree383 wrote:Lem Evans wrote:dfree383 wrote:Versions of that have seen around for awhile never seem to see any running or in any catalogs for sale
Why should you be suprised? Nobody worries about the track or ET or Scoreboard. It's all about the BLOW Bench. That is what's important
![No](https://2img.net/i/fa/i/smiles/kopfschuettel.gif)
Gary Blair- Posts : 221
Gary Blair wrote:dfree383 wrote:Lem Evans wrote:dfree383 wrote:Versions of that have seen around for awhile never seem to see any running or in any catalogs for sale
Why should you be suprised? Nobody worries about the track or ET or Scoreboard. It's all about the BLOW Bench. That is what's important![]()
It be cool to see some more 700"+ BBF's running at more tracks..... Too damn many GM's in the world.
The 'blow bench' as Gary calls it is a good tool. The issue with flow bench is that many people become a slave to it.....keeps them from trying things. Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one.
It's got to the point where people are saying 'flow doesn't matter'. If that's the case why are those crazy guys still designing those taller better flowing heads?
Lem Evans wrote:The 'blow bench' as Gary calls it is a good tool. The issue with flow bench is that many people become a slave to it.....keeps them from trying things. Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one.
Agree on this.
Taller "can be good" no doubt about that.
Gary Blair wrote:Lem Evans wrote:The 'blow bench' as Gary calls it is a good tool. The issue with flow bench is that many people become a slave to it.....keeps them from trying things. Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one.
Agree on this.
LoL, taller. Isn't Lem 7' tall?
68formalGT wrote:Gary Blair wrote:Lem Evans wrote:The 'blow bench' as Gary calls it is a good tool. The issue with flow bench is that many people become a slave to it.....keeps them from trying things. Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one.
Agree on this.
I was referring to cylinder head height
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
I am aware of engines on dynos which had heads swapped out and the lesser flowing heads produced more overall power on the given package than the heads with the higher flow numbers. A lot of this is about combination.Lem Evans wrote:The 'blow bench'....Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one....
Paul Kane wrote:I am aware of engines on dynos which had heads swapped out and the lesser flowing heads produced more overall power on the given package than the heads with the higher flow numbers. A lot of this is about combination.Lem Evans wrote:The 'blow bench'....Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one....
Very true, track performance can be affected as well. I've seen the same with carb's. Great dyno performers but sometimes out performed at the track with with a lesser valued carb. Correlation and building a data base is time consuming and costly.
dfree383 wrote:It be cool to see some more 700"+ BBF's running at more tracks..... Too damn many GM's in the world.
Is that where these heads will shine or will the fit in other applications like the 611 Thor Gen 2 build?
Gary Blair wrote:Paul Kane wrote:I am aware of engines on dynos which had heads swapped out and the lesser flowing heads produced more overall power on the given package than the heads with the higher flow numbers. A lot of this is about combination.Lem Evans wrote:The 'blow bench'....Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one....
That's usually because the flow curve is 'jacked up'. The newer carbs with 5 stage emulsion legs, removable restrictions and a guy that knows how to adjust them resolves that issue.
Plus, a carb on a dyno isn't moving!! That carb on a race car getting air rammed into it at 100+ mph changes the settings a bit!!
A little bit of tunin & tweakin gets the carb dialed into race condition.
BBFTorino- Posts : 997
Lem Evans wrote:Gary Blair wrote:Paul Kane wrote:I am aware of engines on dynos which had heads swapped out and the lesser flowing heads produced more overall power on the given package than the heads with the higher flow numbers. A lot of this is about combination.Lem Evans wrote:The 'blow bench'....Just because one valve job flows 470 cfm and another flows 477cfm dry does mean that the 470 unit won't out perform the other one....
Unfortunate, but true. Happy Dyno, Happy carb, skilled jack up tuner.
BBFTorino wrote:Plus, a carb on a dyno isn't moving!! That carb on a race car getting air rammed into it at 100+ mph changes the settings a bit!!
Good skill to have. May save some money in the long run,
I will give up 20 cfm at .900 lift for 20+ cfm gain at .400 .500 .600 &.700.
Its about the average air moved in the same lift curve. Filling the cylinder the most in the amount of time you have to do it. And how it enters the cylinder.
IDT-572 wrote:I will give up 20 cfm at .900 lift for 20+ cfm gain at .400 .500 .600 &.700.
This is true^^^
There are guys that'll fuck up the short side to get a big number @ .800"-1.00" and take the 'guts' right out of the engine.
Lem Evans wrote:IDT-572 wrote:I will give up 20 cfm at .900 lift for 20+ cfm gain at .400 .500 .600 &.700.
This is true^^^
Absolutely true. Keep those prostitutes out of there.
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Page 1 of 2 • 1, 2
» New Eddy Heads?
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» coolant leak between head and block at head bolt location.
» edelbrock head article
» A460 pistons with edelbrock head
Page 1 of 2
