Cool Header Clamps
Cool Header Clamps Empty Cool Header Clamps
Post  res0rli9 January 28th 2017, 2:58 am
I'm getting the 2nd & 3rd one there cheaper than the 1-5-to-3-0
http://www.ebay.com/itm/3-Tack-Welding-Clamp-Pipe-Exhaust-Set-Range-1-5-to-3-0-Auto-Motorcycle-Truck-/151697067023?hash=item2351d98c0f:g:39cAAOxy0zhTLY9m
http://www.ebay.com/itm/Universal-2-0-to-2-5-Exhaust-Tube-Tack-Welding-Clamp-Weld-Auto-Motorcycle-Tig-/151332721398?hash=item233c2212f6:g:uZMAAOxyjxlTLY7E
http://www.ebay.com/itm/Universal-1-5-to-2-Header-Tube-Tack-Welding-Clamp-Weld-Auto-or-Motorcycle-Pipe-/152213165064?hash=item23709c9408:g:eVIAAMXQydtTLY0d
Cool Header Clamps Empty Re: Cool Header Clamps
Post  DILLIGASDAVE January 28th 2017, 5:14 am
Why not just use a simple hose clamp with 3 or 4 holes drilled around it to hold the 2 tubes aligned & get 3-4 tack welds done. Then remove the hose clamp & finish weld the joint.
Post  res0rli9 February 7th 2017, 12:09 am
DILLIGASDAVE wrote:Why not just use a simple hose clamp with 3 or 4 holes drilled around it to hold the 2 tubes aligned & get 3-4 tack welds done. Then remove the hose clamp & finish weld the joint.
scratch I like that even better.
