Need some drill press table clamps...
Need some drill press table clamps... Empty Need some drill press table clamps...
Post  jbozzelle April 3rd 2010, 9:30 pm
What's everyone use to clamp stuff to their drill press table?
I need to drill some stuff and I don't want it flying off the table...
Also, what are you guys using to center a drill bit on an existing hole? I'm looking to drill some brake rotor hats and hub flanges for larger drive studs and would like to center the bit in the hole that is there to make sure the studs are evenly spaced.
Need some drill press table clamps... Empty Re: Need some drill press table clamps...
Post  Doug Rahn April 4th 2010, 6:58 am
Here you go John. Clamps- http://www.victornet.com/subdepartments/Clamping-Kits/290.html
Center Finder- http://www.victornet.com/alphabetic/Centering-Indicator/391.html
Need some drill press table clamps... Empty Harbor Freight...
Post  posford April 4th 2010, 9:12 am
Or if it's just for general use (non precision) the Vise Grip style work pretty good. They can be had at Harbor Freight real cheap. They have a stud and nut setup that bolts to the table and a jaw with a flat shoe that holds the workpiece.
posford
posford
Post  jbozzelle April 4th 2010, 10:06 am
Thanks guys.
