Delete I found a set
Delete I found a set Empty Delete I found a set
Post  manofmerc February 28th 2017, 5:58 am
I need a couple stud mounted rocker arms to check piston to valve clearance .I will need the sled fulcrums too .Roller style will work also but I need the 1.73 ratio .Thinking of some new heads for my comet and need to check piston to valve clearance and add valve notches .Thanks Doug in Ga.
Last edited by manofmerc on March 4th 2017, 5:34 am; edited 1 time in total (Reason for editing : I found a set)
manofmerc
