What are you using for WOT switch to activate N02 (4150 with choke and kickdown)?
What are you guys using to activate your N02 at WOT on a street application (choke and C6 kickdown)?
I have not been able to find any kind of WOT switch that works with my 4150 style carb.
For now I have a N.O. "Pull-type" elec switch (plunger style) but I think I can do better and its a pain to get it setup correctly.
I have checked Summit and Jegs and there seems to be nothing that fits/works.
Maybe there is a WOT electrical switch that works off of MSD6A box. I should check into that.
Is everyone building their own WOT switch setup - or is there another source (besides Summit/Jegs) to look at?
4604X4- Posts : 108
Re: What are you using for WOT switch to activate N02 (4150 with choke and kickdown)?
I have always used the WOT switch and bracket that Edelbrock makes. Used it on my 4150 based carb, and bought another to use on my Dominator carb. You may need to get a universal bracket since you are running the choke and kickdown though.
kjett- Posts : 1169
Thanks. I'll check out the Edelbrock switches, maybe I missed something.
As I was typing the original post - the "rpm activated switch" idea came to mind, and since posting I have looked at a couple (MSD, Summit, etc). I'm thinking this may be the easiest and cleanest way to mimic WOT activation.
Anyone using one of these? If so, for nitrous what rpm would you set the switch to activate at (assuming max rpm is 6000)?
Would you want nitrous to come on at 3000 rpm?
I'm not sure what a RPM a "mechanical WOT switch" would activate at/correlate to.
4604X4- Posts : 108
this is what we use for the mechanical WOT switch ,it's a micro switch used on Irrigation pivots ie: Zimmatic
![What are you using for WOT switch to activate N02 (4150 with choke and kickdown)? 20160629_200759_zpseknl0inf](https://2img.net/h/i58.photobucket.com/albums/g266/fmerkl/20160629_200759_zpseknl0inf.jpg)
along with a window switch in the ignition system
Frank Merkl- Posts : 1524
PS we also use this switch for the transbrake as there cheap as in about $12
» Kickdown on a C6
» Lokar C6 shift linkage and kickdown
» Who makes a trans kickdown linkage kit for C6
» CJ Choke parts
» hardwire electric choke
» CJ Choke parts
