1.83 rockers
1.83 rockers Empty 1.83 rockers
Post  snuff98 March 14th 2017, 1:02 pm
I now using 1.73 comp gold rockers, what would be pros vs cons of going from 1.73 to 1.8 or 1.83 rockers. Cam is 274 @ .050 .745 lift.
any suggestions on brand and type of rocker?
snuff98
1.83 rockers Empty Re: 1.83 rockers
Post  dfree383 March 14th 2017, 1:17 pm
Never seen a 1.83
You'll gain a slight bit of lift and duration with the higher ratio rockers
Post  snuff98 March 14th 2017, 3:55 pm
Scorpion now offers a 1.83. Never used Scorpion before always Harland Sharp or comp. Just wondering if there would be adverse affects on lifters or valve train in general making the cam seem to have faster opening and closing rates.
snuff98
Post  dfree383 March 14th 2017, 4:42 pm
Depends on the cam and parts you're  using
Only thing adding ratio will tell you if you motor has the right cam or not.
