Ford 460 Crankshaft dimensions/blueprints
RW460
Im looking for dimensions, specifications, or blueprints of a 460 crankshaft. Ive been looking for ages and it seems to be non-existent. A PDF version that has been created in a vectoring program would be great, but beggars can't be choosers.
RW460- Posts : 9
Re: Ford 460 Crankshaft dimensions/blueprints
You may have to get an actual crank, and record all its dimensions.
BBFTorino- Posts : 999
That was what I was afraid of... Bump for luck
RW460- Posts : 9
Emails sent to Scat, Eagle, Callies, and Winberg about specs... Fingers crossed
RW460- Posts : 9
What do you need the dimensions for?
jbozzelle- Posts : 3705
I want to draft a CAD model of a crankshaft, specifically a flat plane crank. I'd have a buddy eventually CNC it for me.
RW460- Posts : 9
Flat plane 460........
maverick- BBF CONTRIBUTOR
I know its blasphemous, but if/when it's done it will we available to anyone who wants the CAD file.
RW460- Posts : 9
Could he reverse engineer one?
Flat plate would be cool !
Give allot of thought to the TREMENDOUS vibration that comes along with a flat crank. You might end up sorry you wasted all the time and money making one. Long stroke make the situation worse.
gt350hr- Posts : 662
I think the Ford voodoo is the biggest flat plane v8 made at 5.2L. There is a limitation on size with a flat plane due to vibrations, or were you planning on some kind of counter shaft or something?
SLord82- Posts : 145
NVH was one of my first considerations, specifically secondary vibration/balance. There are a multiplicity of ways in which to solve said problem and it will be fun figuring it out. I will not purchase any crankshaft materials until I've completed finite element analysis and I am confident I wont wreck my block. The potentially most expensive part of this endeavor will be the problem of reduced reciprocating mass and limited/non-existent piston and rod selection.
RW460- Posts : 9
If i were to pursue a balanced shaft approach, I imagine it would reside in a crankcase assuming oil pump clearance and feeding said shafts were a nonissue (omitting cost of course).
Ford has a few patents out of Germany for eccentric weights on the crankshaft.
Patent:https://www.google.com/patents/US9285012#backward-citations
Ford seemingly got stingy with the picture
Pic:http://pdfpiw.uspto.gov/.piw?Docid=09285012&homeurl=http%3A%2F%2Fpatft.uspto.gov%2Fnetacgi%2Fnph-Parser%3FSect2%3DPTO1%2526Sect2%3DHITOFF%2526p%3D1%2526u%3D%2Fnetahtml%2FPTO%2Fsearch-bool.html%2526r%3D1%2526f%3DG%2526l%3D50%2526d%3DPALL%2526S1%3D9285012.PN.%2526OS%3DPN%2F9285012%2526RS%3DPN%2F9285012&PageNum=&Rtype=&SectionNum=&idkey=NONE&Input=View+first+page
RW460- Posts : 9
Randy at Winberg Cranks hooked it up with some info (stock 460):
Bore and main spacing is 4.9"
Front and rear cwt. width is 1.140 +/- .020
Middle cwts width is .725/.735
Main journal width is 1.125. 3" dia.
Rod journal width is 2.020. 2.5 dia.
RW460- Posts : 9
» BBF Boss dimensions
» Motorsports A460 block and head blueprints
» Blueprints
» 460 Lifter bore Blue Prints
» engine dimensions
» Blueprints
» engine dimensions
