intake recommendation
just picked up a set of c9 heads for my current build project 557 stroker also have a holly 850 cfm double pumper i'm new to the build world and looking for recommendations a lot of the builds online i see trick flow being used but going to rework the heads port polish larger exhaust vales still trying to decide flat tappet or roller rocker and just trying to see whats worked well for others or any good reads or suggestions
stroker557- Posts : 2
Re: intake recommendation
stroker557 wrote:just picked up a set of c9 heads for my current build project 557 stroker also have a holly 850 cfm double pumper i'm new to the build world and looking for recommendations a lot of the builds online i see trick flow being used but going to rework the heads port polish larger exhaust vales still trying to decide flat tappet or roller rocker and just trying to see whats worked well for others or any good reads or suggestions
For starters:
Vehicle Hood Clearance ...?
Weight ...?
Gearing ...?
Type usage 80% of the time ...?
dont have a car/truck to put it in yet building the motor first but in the end it will go in a late 60's f100 or mid 50 sedan 80% of the time will be just cruising around town running to the track every once in a while
stroker557 wrote:dont have a car/truck to put it in yet building the motor first but in the end it will go in a late 60's f100 or mid 50 sedan 80% of the time will be just cruising around town running to the track every once in a while
The hood-line of the vehicle will determine the maximum height of whatever intake manifold; the best manifold for the application, (Trick Flow "Track Heat"), is usually to tall for a regular car.
EVERYTHING should be determined by the particular vehicle and how it is going to be used.
» Need an intake recommendation
» intake recommendation
» A460 Intake Recommendation -- Tunnel Ram vs. Single Plane
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» Burnout recommendation
