intake recommendation
gt350hr
jm
hello i am building a low buck 460 in my 79 bronco. i installed a good set of 69 heads with a mild clean up and a good back cut valve job on a stock bottom end. i am using a mild 214-224 cam on a 112 c/L. 512 lift on the intake and a 538 on exhaust. i was going to use my 69 cast iron intake or has anyone used a stock cj intake on a mild 4x4? if so what would you prefer?
jm- Posts : 65
Re: intake recommendation
jm wrote:hello i am building a low buck 460 in my 79 bronco. i installed a good set of 69 heads with a mild clean up and a good back cut valve job on a stock bottom end. i am using a mild 214-224 cam on a 112 c/L. 512 lift on the intake and a 538 on exhaust. i was going to use my 69 cast iron intake or has anyone used a stock cj intake on a mild 4x4? if so what would you prefer?
Are those heads CJ intake port size or passenger car intake port size ...?
the heads are standard port heads 1968 heads. i know that back in the day the marine motors had this set up. not sure if it will kill bottom end in this application
jm- Posts : 65
The "SCJ" ( iron Holley) WILL make more power than the '69 intake. Ford did that on their marine 460s despite the obvious port mismatch. They also touted the merits in the old "MuscleParts" book. 25 or so HP over the "regular 4V intake. I am not sure about the "CJ" ( Quadra Jet) style. I have both , but am only using the Holley version. The trouble is the prices have been on the rise lately for some stupid reason.
gt350hr- Posts : 662
Performer RPM is the best street manifold IMO if you can get one right now.
I would say Performer RPM if you plan on racing around ... But being a truck and based on your specs a normal Performer will do you well IMO.
Gregaust- Posts : 625
thanks for the replies guys. i now the old stock 69 intake will be the best maniflod for torque under 3000 rpms. just wondering about using my cj intake and wanted some one to chime in that actually used a cst iron cj intake on a regular small port head in a truck or 4x4 in a MILD application. as things is i am probably going to install it and will post back when i am taking it for a drive after the cam break in!!
jm- Posts : 65
The factory intake will likely do all you need . Not Big block but I have done a few 351 Clevelands with factory cast intakes , they actually do ok . I'm not talking all up HP but a nice driver .
Weiand Stealth
https://www.holley.com/products/engine/intake_manifolds/carbureted_intake_manifolds/dual_plane/parts/8012
Mark O'Neal- Posts : 286
mystang460 and mitch huested like this post
jm wrote:thanks for the replies guys. i now the old stock 69 intake will be the best maniflod for torque under 3000 rpms. just wondering about using my cj intake and wanted some one to chime in that actually used a cst iron cj intake on a regular small port head in a truck or 4x4 in a MILD application. as things is i am probably going to install it and will post back when i am taking it for a drive after the cam break in!!
I did , third reply. More bottom end power that the aftermarket aluminum manifolds AND the small port '69 too.
Scott Foxwell likes this post
just letting every one know that the bronco works like a charm! the old cj intake works great with this combo. going to look for a holley spread bore carburator. running a adapter plate and a 625 carter carb for now
jm- Posts : 65
Mark Miller and Scott Foxwell like this post
I knew you'd like it.
jm wrote:just letting every one know that the bronco works like a charm! the old cj intake works great with this combo. going to look for a holley spread bore carburator. running a adapter plate and a 625 carter carb for now
Why not find a good QuadraJet like that intake was designed to use ...?
You get the same results bolting a 4v Cleveland intake on a 2V engine.gt350hr wrote:jm wrote:thanks for the replies guys. i now the old stock 69 intake will be the best maniflod for torque under 3000 rpms. just wondering about using my cj intake and wanted some one to chime in that actually used a cst iron cj intake on a regular small port head in a truck or 4x4 in a MILD application. as things is i am probably going to install it and will post back when i am taking it for a drive after the cam break in!!
Scott Foxwell- Posts : 419
» Need an intake recommendation
» ? Cam Recommendation ?
» Cam Recommendation
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» New Ford Racing Performer RPM intake ported and NIB Victor intake for Dominator
