Driven FR50 and Morel Lifters....
There has been some questions from the Engine Builders that they want to run a 50W oil. The “W” winter rate doesn’t really tell whether you can use a specific oil with hydraulic roller lifters as I have learned from both John Callies and Lake Speed Jr. What does matter is the centistoke number.
Driven has supplied this chart on flow ratings on the Driven FR50 and other popular 50W oils:
Ambient Temperature Oil Flow Rates
Oil Driven FR50 VR1 Brad Penn
SAE 5W-50 20W-50 20W-50
60F 328 cSt 786 cSt 627 cSt
75F 213 cSt 451 cSt 373 cSt
90F 144 cSt 275 cSt 235 cSt
High Temp Flow (for reference)
275F 9 cSt 9 cSt 9 cSt
300F 7 cSt 7 cSt 7 cSt
I have talked with John Callies at Morel about the Data above and he said the FR50 will work with the Morel lifters. For those that want to run a heavier oil you can run this with your Morel lifters.
Straubtech- Posts : 293
Re: Driven FR50 and Morel Lifters....
Straubtech wrote:There has been some questions from the Engine Builders that they want to run a 50W oil. The “W” winter rate doesn’t really tell whether you can use a specific oil with hydraulic roller lifters as I have learned from both John Callies and Lake Speed Jr. What does matter is the centistoke number.
That's good to know - I've been using Driven LS-30 for most hyd. rollers with pretty good results, wonder what those numbers are?
pmrphil- Posts : 171
pmrphil wrote:Straubtech wrote:There has been some questions from the Engine Builders that they want to run a 50W oil. The “W” winter rate doesn’t really tell whether you can use a specific oil with hydraulic roller lifters as I have learned from both John Callies and Lake Speed Jr. What does matter is the centistoke number.
I will ask for the numbers.
LS30
60F 204 cSt
75F 132 cSt
90F 89 cSt
275F 6 cSt
300F 5 cSt
Hello Chris,
What cSt numbers are required by the Morel Hyd roller lifters? Is there a range?
I also assume most oils when cold would not function well (high cSt number) at high rpm with Morel lifters.
Not that anyone would take a trip down the 1/4 mile with a cold engine.
Cheers
Cheers
68galaxie- Posts : 351
68galaxie wrote:Hello Chris,
Cheers
At 90 degrees 150 cSt. The marine offshore guys do all the time. Worked all week.....get to the marina. Load the cooler. Start the boat. Pull out of slip. Hit the the NO Wake buoy on the "Let her rip side" push the stick all the way forward. In these cases most can be at the bouy in 10 minutes or less. I had a Merc 525. It took a little over 14 minutes with a closed cooling system to the oil temp to reach 140 degrees. Superflow tells us don't pull an engine until your at 180 degrees. This part of the HP market does it all the time.
Thank you Chris.
from the Brad Penn 20-50 semi synthetic Penn-Grade 1 spec sheet it looks like this oil would work also - with some attention
to oil temperature before high rpm use. (Oil pan heater)
20-50:
@ 40C (104F) 159 cSt
@ 100C (212F) 20 cSt
15-40:
@ 40C (104F) 113 cSt
@ 100C (212F) 15.5 cSt
100C is what I would assume "normal" oil operating temperature when engine warmed up.
20-50:
15-40:
Straubtech wrote: Superflow tells us don't pull an engine until your at 180 degrees. This part of the HP market does it all the time.
I guess I'm doomed. My hooptie never sees 180°
Curt- Posts : 2791
Curt wrote:Straubtech wrote: Superflow tells us don't pull an engine until your at 180 degrees. This part of the HP market does it all the time.
Let me clarify...That is oil temp.
Straubtech wrote:Curt wrote:Straubtech wrote: Superflow tells us don't pull an engine until your at 180 degrees. This part of the HP market does it all the time.
Same
Curt- Posts : 2791
» new morel lifters no oil to top?
» Where to buy Morel lifters?
» Morel lifters
» Question about Morel .936 keyway lifters
» Buyer Beware of Fake Morel Lifters.....
» Morel lifters
