Pistons - 4.440, 4300 strke
Pistons - 4.440, 4300 strke Empty Pistons - 4.440, 4300 strke
Post  HorsinAround June 14th 2017, 3:16 pm
Looking for a set of forged domed pistons 4.440 bore, 4.300 stroke that will get me in 15:1 C/R with 75cc heads. What have you got?
http://www.frontpagefab.com
Pistons - 4.440, 4300 strke Empty Re: Pistons - 4.440, 4300 strke
Post  fordmonsta June 15th 2017, 11:45 am
What heads are you running
fordmonsta
Post  HorsinAround June 15th 2017, 1:36 pm
Ordering the 75 cc 315 AFR's Monday. I am assuming that I can mill on the dome if needed and/or cut valve pockets if needed.
Post  fordmonsta June 15th 2017, 2:48 pm
Ive got some brand new icon flat tops but they are for a460 heads would make about 12.5 with a 4.3 stroke
fordmonsta
Post  HorsinAround June 15th 2017, 4:45 pm
Thanks, trying to get the compression higher that that. This motor will be on alky and alky loves compression...
Post  DanH June 18th 2017, 2:40 pm
Have used 4.470 bore domdomes.
DanH
Post  Paul Kane June 19th 2017, 1:16 pm
HorsinAround wrote:Looking for a set  of forged domed pistons 4.440 bore, 4.300 stroke that will get me in 15:1 C/R with 75cc heads. What have you got?
I have a set of 4.44" Venolia dome tops, I estimate 9-10cc domes, for std valve layout, 1.41" c/h so with a 4.3 stroke you'd use a 6.70"-6.75" aluminum rod depending on your block deck height.  I might have a set of rods, too, so if you're interested let me know if pistons only or pistons & rods and I'll see what I can do.
