Pro Comp headed 501 engine dyno'ed
+9
1EFF100
427HISS
Gregaust
13 posters
Pro Comp headed 501 engine dyno'ed Empty Pro Comp headed 501 engine dyno'ed
Post  rmcomprandy June 27th 2017, 7:58 pm
I thought someone might be interested in this.
This engine is for a street rod with an exposed engine so, these heads were provided by the owner as they are very plain outside and polish well. We put it on the dyno to break-in the cam, look for leaks and obvious things to be addressed.
The power numbers about knocked us over after we put-in the inner valve springs,
619 horsepower at 6,400 RPM and 582 lb/ft of torque at 4,600 RPM
4.390" bore x 4.14" stroke ... offset ground, stock 460 crankshaft
A connecting rod set from a 8.0 liter GM big block ... 6.696" long bushed small end to .990"
ICON forged flat-top pistons ... IC855/KTD
10.5/1 compression ratio
Bowl ported heads not flowed but, previous heads of this type are around 300/200 cfm
2.19" intake valves & 1.710" exhaust valves
Lunati hydraulic flat-tappet custom camshaft with their Micro-Trol lifters
  288/297@ .006" - 245/250@.050" - 159/162@ .200" - .359"/.362" lobe lift - 111 separation +2; 109 intake center-line.
  theoretical valve lift with 1.73/1 Lunati Voo-Doo rocker arms = .621"/.626"
polished Trick Flow "track Heat" intake manifold
Quick Fuel "black Diamond" BD-830 carb with electric choke
1 7/8" to 2" stepped primary - 3 1/2 collector 20" long dyno headers.
It is a shame this is for a cruiser / parking lot queen. He'll probably never use it.
Pro Comp headed 501 engine dyno'ed Empty Re: Pro Comp headed 501 engine dyno'ed
Post  Mark Miller June 27th 2017, 11:01 pm
rmcomprandy wrote:I thought someone might be interested in this.
Nice horsepower and torque numbers!!! Smile Smile
Post  BigBlockRanger June 28th 2017, 3:37 pm
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Post  Gregaust June 29th 2017, 5:10 am
I'd not have guessed that , good work Cool
Gregaust
Post  stanger68 July 7th 2017, 12:03 am
In a nutshell would you say the pro comp is basically a aluminum DOVE head?
Post  rmcomprandy July 20th 2017, 9:37 am
stanger68 wrote:In a nutshell would you say the pro comp is basically a aluminum DOVE head?
NO ... it has 93cc combustion chambers and a much better exhaust port.
A closer comparison would be to a production D2OE-AB Police Interceptor head but, having better exhaust ports.
Post  BOSS 429 August 1st 2017, 11:53 pm
NICE
Post  BBFTorino August 2nd 2017, 1:24 am
Any pics of it??
Post  rmcomprandy August 2nd 2017, 12:05 pm
BBFTorino wrote:Any pics of it??
NO ... I don't take photos of anything unless the customer specifically asks for it to be done.
It's purple with polished aluminum parts and chrome.
Post  427HISS August 9th 2017, 10:21 pm
Sent you a PM.
427HISS
Post  427HISS August 12th 2017, 4:47 pm
I don't know if you received my email, as my message was sent to my address ?
427HISS
Post  rmcomprandy August 14th 2017, 4:45 pm
427HISS wrote: I don't know if you received my email, as my message was sent to my address ?
A reply was sent the same day I received it ... I just sent it again.
Post  427HISS August 14th 2017, 5:25 pm
I have no messages, so I'll contact a moderator regarding this issue.
Regards.
427HISS
Post  1EFF100 August 20th 2017, 6:48 pm
Nice! Cool
1EFF100
1EFF100
Post  nickpohlaandp October 14th 2017, 6:51 pm
Aren't the ProComp heads the ones on eBay made in China that I see a lot of people talk bad about? If they're the same ones I'm thinking about you are the FIRST person I've ever seen to give first hand feedback on them. Not bad.
nickpohlaandp
Post  5pointslow October 14th 2017, 9:32 pm
nickpohlaandp wrote:Aren't the ProComp heads the ones on eBay made in China that I see a lot of people talk bad about? If they're the same ones I'm thinking about you are the FIRST person I've ever seen to give first hand feedback on them. Not bad.
they are and similar to a aluminum version of D3 heads if im not mistaken
this build deffinitly shows in the right hands re-worked they will work in the right application and take some weight off the motor as well
5pointslow
5pointslow
Post  nickpohlaandp October 14th 2017, 11:23 pm
That's a cool deal, especially for a street rod that's more for looks than trying to peel the skin off your face.
nickpohlaandp
Post  5pointslow October 15th 2017, 6:05 am
Still 600 hp in right car go mid 10s
5pointslow
5pointslow
Post  Bosskk1786 October 16th 2017, 7:49 pm
Randy this build has really inspired me to try these heads. In your testing is it advantages to run a cam with a closer duration split because the exhaust port is good and keep the lift in the mid .600's because the intake isn't ideal?... I remember reading Scotty says the intake flow gets ugly above .600
Bosskk1786
Post  rmcomprandy October 17th 2017, 6:50 pm
I have not flogged camshafts with these heads; this was the same grind cam I would use with an iron D3 head for that same purpose and this is what it got in that engine. Never tried anything else.
The lobe areas and duration split is already pretty close for a big block Ford application.
Post  Bosskk1786 October 17th 2017, 7:31 pm
I really would like to try these heads. I need the bigger combustion chamber and stock valve location for the 532 rotating assembly I have to get the compression street friendly. I don't want to get Edelbrock heads cause of the budget I'm trying to stick too. It's going into a 94 lightning with a 175-200 shot of nitrous shooting for 10's... With a small solid roller do you feel these heads could support 650 to 675 hp?... I've researched these quite a bit but most of the discussion turns into fighting and I know you are a straight shooter on technical questions... Thanks in advance
Bosskk1786
Post  rmcomprandy October 18th 2017, 10:04 am
The castings can ... I would not trust the Pro Comp components.
Post  Bosskk1786 October 18th 2017, 3:20 pm
very good.... Thank you Randy
Bosskk1786
Pro Comp headed 501 engine dyno'ed Empty Intake
Post  duggy2145 November 23rd 2017, 6:55 am
Hi Randy,
Given the mild nature of the engine, would you expect a better Low/Mid curve using a less aggressive intake like a Wiend Stealth or RPM Airgap?
Cheers
duggy2145
Post  rmcomprandy November 23rd 2017, 11:28 pm
duggy2145 wrote:Hi Randy,
Cheers
A Wiand "Stealth" is a terrible part throttle intake manifold and the #8012, (needed to match these smaller intake ports), is even worse than the #8021 Stealth on CJ sized ports.
With this camshaft, I don't see the "AirGap" being much better on the bottom but, maybe transient part throttle response would be improved in a heavier car.
Though, this street rod is under 2,500 pounds.
