77 cobra with coyote 5.0 swap .?
whitefield
77 cobra with coyote 5.0 swap .? Empty 77 cobra with coyote 5.0 swap .?
Post  whitefield July 5th 2017, 11:48 pm
Have a customer wanting to do a 5.0 coyote swap with c4 in a 77 Cobra. I have not been able to find any info or pics of this swap being done. any advice or helpful info would help. pics are a plus. Thanks Whitey
whitefield
whitefield
77 cobra with coyote 5.0 swap .? Empty Re: 77 cobra with coyote 5.0 swap .?
Post  jasonf July 6th 2017, 9:17 am
There is a few 5.0l swap groups on facebook. You could try there if you don't get any answers here.
5.0 Coyote Powered: The Swap Of Greatness
https://www.facebook.com/groups/237838529753389/
Coyote's Only , parts forsale or trade
https://www.facebook.com/groups/807865469232200/
Post  dfree383 July 6th 2017, 9:26 am
Good luck fitting the wide ass engine in a mustang II with stock aprons and booster master cylinder a 302 pushrods motor is tight and a 351c is about as tight as id want to work on one.
Do a lot of measuring befor you tear into it.
Post  whitefield July 6th 2017, 12:42 pm
Both of these cobras I have been given the opportunity to work on are drag cars. One is a 302 and that is the one that wants to go with the coyote for next season of racing. The other has a 351C in it .
This is a new adventure for me ! study I figure the motor will fit mount wise as the bottom of the engine is pretty narrow. The brake booster will be eliminated and all things not necessary for safety or the occasional 30 mile cruise. Trimming and bracing the front for safety and clearance will be the biggest hurdle along with the headers.
Thanks for the info already given and all info and advise is welcomed
whitefield
whitefield
Post  BBFTorino July 6th 2017, 2:41 pm
I think changing out the whole front end would be the easiest way to get the best fitment.
A Fox or newer gen Mustang tubular front end (aftermarket K member) grafted onto the chassis of the Mustang II will probably work best.
Its a whole lot of fabrication!!
Post  dfree383 July 6th 2017, 4:20 pm
BBFTorino wrote:I think changing out the whole front end would be the easiest way to get the best fitment.
Basically a tube / strut racecar front end
Post  dr's wife racing July 7th 2017, 2:47 pm
Off the subject but do you have any headers for a 302 in a mustang ii
dr's wife racing
dr's wife racing
Post  whitefield July 7th 2017, 4:58 pm
dr's wife racing wrote:Off the subject but do you have any headers for a 302 in a mustang ii
I do sir ! I will see what kind of shape they are in and try txt you some pics
whitefield
whitefield
Post  dr's wife racing July 8th 2017, 10:45 am
Okay. Thanks. I have a total change of plans since I canned the turbo deal.
dr's wife racing
dr's wife racing
Post  nuclearcobra May 17th 2018, 4:31 pm
That would be cool and huge in there , I Been wanting to put a 351w based motor in mine one day , I have a 396'' eagle kit i wanna use with the kaase jegs heads. This is the 302 with those heads and valve cover to valve cover is the same width as a 351w because of the height of the heads.
77 cobra with coyote 5.0 swap .? 38978871154_e607686e57_zIMG_2200 by Nuclearcobra, on Flickr or just go for it and stuff this in it Very Happy
77 cobra with coyote 5.0 swap .? 39348509970_e6491ff225_z001 by Nuclearcobra, on Flickr
nuclearcobra
nuclearcobra
