429/460 Overheating Issue
+9
4604X4
zbob
Speedwaypj
13 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: 429/460 Overheating Issue
Speedwaypj wrote: jasonf the video was prior to me installing the shroud......Thx for the link.
But does the shroud go 2' back to the engine?
Off topic but why does your radiator lay forward and not back all the cobras I have seen?
jasonf- BBF CONTRIBUTOR
Yes, the fan is about 1 1/2 ft from radiator......
...with the Antique & Collectibles body/build, the radiator faces front to gain the most air efficiency......
Speedwaypj- Posts : 23
Expansion/surge tank (and overflow tank);
I integrated a 2qt expansion/surge tank (and 1 qt overflow tank);
Initial timing @ 13 BTDC ; Total @ 33 BTDC (w/o vac)
80 F ; Ran Aux garage fan.
Much better; after 45 minutes of running (@idle) radiator pressure only went to 6psi and temp stayed under 210F.
So I'll plan an electrical Puller with high CFM...and the mechanical Fan
Time to move past this now.
Again, thanks all!
PJ
Again, thanks all!
PJ
If your radiator cap is the highest point in the system ,and it's completely full of water , it will push out a quart every time it gets up to about 140 degrees because of the water has no where to go as it heats and expands.
You know, I run 460's of all shapes and sizes on my run in stand. It has a big after market bolt in fox radiator and one 12 inch electric fan.
With a Meziere standard flow or a Moroso belt drive old school running a stock pump, I have to turn off the fan to get them to heat up.
Small ford or chevy will get hot after 20 min with same set up.
Speedwaypj wrote:...........So I'll plan an electrical Puller with high CFM...and the mechanical Fan.........
IMO if you're going to use a high CFM elec fan(s) I honestly don't see any reason to also use a mech fan as well.
DILLIGASDAVE- Posts : 2262
Page 3 of 3
