coil overs
coil overs
for a 79 fairmount with an iron block P51 545 what front coil over spring rate is recommended drag use only
Larry Williams- Posts : 884
Re: coil overs
The most commonly used front spring rate you will find on the net is 175lb for the front for the foxbody's so I would think it would be a good place to start with your car. I run them in my 87 with good results, I can't speak to the rear as I use Team Z stock location stuff.
BigRigTech- Posts : 763
Re: coil overs
this isn't my car but I did build the motor. in my fox body I now use 164 rate. up from 150's I am trying to help a friend cure the lack of traction he has. the motor dyno'd at 853 with gobbs of torque
Re: coil overs
Of coarse weight the car. My guess would be 25o on the front springs
airford1- Posts : 192
» Who Makes a Good Rear Coil Over Double Adj. Shock
» Anyone mount their coil overs in front of the rear end with ladder bars?
» Moroso oil pan, Strange coil overs
» Jegs double adjustable coil overs
» strange single adjustable coil overs with springs
