water outlet
water outlet Empty water outlet
Post  charlie 1 August 13th 2017, 3:28 pm
HIYA FOLKS I know this is a old topic but maybe some new answers. I kinda figured that my water neck might give some problems , and it has. Trying to put dist. in I found that it wouldn't go down all the way cause of it hitting the water neck. Has anyone ever modifyed one? I've read the old post's on here and haven't seen anything.If I have to I'll notch it and weld a inset piece in it. Any info would help before I cut. THANKS Smile
charlie 1
water outlet Empty Re: water outlet
Post  wayney August 13th 2017, 5:07 pm
not sure what intake/ distributor combo you are running but I use a 96-97 efi 460 outlet from a truck .it has a flat cast in from the factory .
thanks, wayne
wayney
water outlet Empty outlet
Post  charlie 1 August 14th 2017, 5:15 pm
I am running a  stealth manifold and a hei dist. If the dist. was 1/4 taller from block to base it would be fine. Might have to make one. Neutral Have made a lot of stuff for this. Will check out the one u mentioned .thanks
charlie 1
Post  Doug Rahn August 15th 2017, 10:57 am
Check and see if any of these will work for you. Made by Four Seasons (down side made by a Chinese Company and available on Summit Racing) Part# 85185, 84860, & 84859.
