AJE Suspension Tubular K-Member 1965-1970
For you guys that want more shock tower room.
Way better than the Mustang 2 deal.
http://www.cjponyparts.com/aje-suspension-tubular-k-member-1965-1970/p/KM20/?gclid=EAIaIQobChMI7Ojdv_rr1QIVyJEbCh1k1QwBEAYYASABEgJIVPD_BwE
res0rli9- BBF CONTRIBUTOR
Re: AJE Suspension Tubular K-Member 1965-1970
AJE does make some fine products and I personally use their K member on my Foxbody. The only issue I have with their early Mustang unit is you still have to use the upper portion of the original shock tower which is cut back at an angle down to the frame rail to accommodate the McPherson Strut type suspension.
Mustang 2 type totally eliminates the towers and you have the room to install the biggest of engines, even a big Jon Kaase Boss 9 or one of the really wide ass Coyote 5.0’s. I recently came across a company called “Mustangs to Fear”. They have a front sub frame assembly that completely replace the original front rails in a short and long version. The long version extends all the way back to the rear suspension front leaf spring eye. They also have a front inner fender panel that is almost full length to replace the originals with the shock towers.
http://www.mustangstofear.com/page.php?page=parts_catalog&yr=67-68&cat=suspension&scat=front_subframes
http://www.mustangstofear.com/page.php?page=parts_catalog&yr=67-68&cat=sheet_metal&prod=engine_compartment_panels
http://www.mustangstofear.com/pages/subframe_installation.html
» TUBULAR FT. END FROM FIREWALL FORWARD
» rear suspension for a 1965 street strip F100...
» Suspension for 1970 Cyclone.
» 1970 Mustang AJE front suspension conversion.
» 429 cj engine 1970 and 1970 429 rug au toploader set up plus more
