Rings
Rings Empty Rings
Post  ctdck September 22nd 2017, 9:31 pm
Need some help, was wondering if I can take .060 over compression rings and file fit them for standard bore ? If not can you explain. Thanks
ctdck
Rings Empty Re: Rings
Post  rmcomprandy September 22nd 2017, 11:55 pm
ctdck wrote: Need some help, was wondering if I can take .060 over compression rings and file fit them for standard bore ? If not can you explain.                      Thanks
.006" over ... yea. ____________ .060" oversize ... not a chance it could seal ok.
Post  BBFTorino September 23rd 2017, 2:04 am
Because their diameter is made to match the bore size. You cut em down too much and there will be gaps between the rings and the cylinder walls.....which would be like not running any rings at all!!
