Engine Masters 414" stroker 351W street/strip engine
600 peak horsepower @ 6,400, 6,500 & 6,600 RPM
550 lb/ft peak torque @ 5,000 RPM
over 500 lb/ft of torque from 3,700 RPM through 6,300 RPM.
Early 70's 351W block 4.058" bore
SCAT 4" stroker crank - 4.000" stroke
6.200" Scat h-beam rods
Race-Tec custom reverse dome pistons, with heat barrier coated crowns, radial gas ports - 10.8/1 compression
Ford Motor Company 1.5mm x 1.5mm x 4mm ring pack
Cometic head gaskets
Edelbrock Performer RPM Heads, CNC ported - 2.062" intake & 1.590" exhaust valves
Solid lifter tight lash custom 3 lobe-profile camshaft, .580" lift with lightweight Comp Cams lifters
FRPP valve springs
Edelbrock Victor Jr. Manifold - port matched
Mustang reverse rotation water pump
Ford Duraspark distributor
FRPP damper SFI approved
$7,500.00 + the ride
FRPP valve springs
» 572" A460 hydro roller street strip track engine
» Engine Masters 534 Boss Engine and BBF 72 Torino in the new PHR Magazine.
» 347+5 Engine Masters Engine
» Are Kings HP good for a 521 stroker street strip?
» Engine masters????
