How much gap for nitrous?
capncruncher1965
My plugs are AR33 just shooting 150
capncruncher1965- Posts : 131
Re: How much gap for nitrous?
i would start around .045 or less , maybe someone else will chime in , what is the compression ?
9.5to1
9.5to 1 and I'll be running 110 gas
bruno wrote:i would start around .045 or less , maybe someone else will chime in , what is the compression ?
^^^^^^^^ This, a 150 kit on race gas is not going to blow the candles out unless you are running a weak factory ignition in which case -.010 or don't hit the jug until the ignition is upgraded.
FalconEh- Posts : 1448
Digital 6 box
Box is a digital it works everything cuts it on at 3000 grand and off at 6200 it also pulls out the timing.
The bigger the hit, the smaller the gap!! You are fine at 150 shot with .035-.045"
BBFTorino- Posts : 999
ran the stock ford distributor ,elcheapo eglin box with an old Accel super coil , down to 7.60's @ 186 mph ! never a problem !! plug gap at .022" spent $1500 on the greatest latest ignition system , performance gain "0" still ran the plug gap at .022" still ran the same Numbers!!!
Frank Merkl- Posts : 1524
run a stock dist. with a msd 6al autolite ar3934 with .035 gap 28* timing 65n 52 f stock bottom end
quick 52- Posts : 612
My gap is good time to go test
Waiting for the weather to get better. Ready to head to the track.Thanks guys for all your replys
