7.3 flywheel
7.3 flywheel
Came across a 95 f-350 daully for a steal so i bought it .The guy told me it needed a flywheel ,at idle sometimes it will rattle and idle a little rough then it will pass and smooth out sounds fine , little time goes by it will do it again.(oh yeah it is a 5-speed) the clutch works good shifts good motor is real strong just has that rattle.So i guess my ? is could it be something else i have heard flywheels knock not really rattle never owned a deisal before so it is new to me. thanks for any help Jimmy
BBFmustang- BBF CONTRIBUTOR
Re: 7.3 flywheel
Sounds like the Zf5 dual mass flywheel rattle to me, Some will rattle forever like that and some let go at the worst possible moment. Here's a great deal of info for you. http://www.oilburners.net/forums/showthread.php?t=33422&highlight=dual+mass+flywheel Search dual mass flywheel over at OB for days of enlightenment.
IDIeselman- Posts : 107
Re: 7.3 flywheel
thanks for the info will get rite on it ,i do alote of traveling dont need to let go somewhere in the middle of nowhere .thanks again
Re: 7.3 flywheel
Put a LUk SMF kit in it and be done.
Re: 7.3 flywheel
richter69 wrote:Put a LUk SMF kit in it and be done.
^^^^What he said^^^
http://www.clutchcityonline.com/dualMassFlywheel.htm
Re: 7.3 flywheel
that is what im going with ,Jon thats why i sent you a pm yesterday about it thanks Jimmy
Re: 7.3 flywheel
Jimmy go ahead and get a new slave cyclinder and master cyclinder why you have it down most of the time if they are old and you put the new pressure plate on them they go out not long after that learn that the hard way back when I worked with Tony Aycock and his Dad on the 10 wheelers. Layed on the side of the road in the rain in Lumber City putting a slave cyclinder that should have been put in with the clutch.
Jim
Jim
Richter69
I put the kit in you mentioned and I have a question. I have more noise and vibration now which is I feel is normal. Are the fly wheels balanced? I seem to have a vibration around 2200 rpm with a 7.3 - 5 speed. Goes away after I speed up.
The kit works great besides the additional noise.
Tom
Tom
747JetMech- Posts : 272
Re: 7.3 flywheel
Its normal.
Its gear rollover your hearing. The dmf is much better at dampening the rollover noise out.
» Engine Swap Flywheel question/ 400M Flywheel on a 460?
» 390 flywheel
» HD 429 flywheel
» 460 flywheel questions. please help.
» WTB 460 flywheel
» 390 flywheel
» HD 429 flywheel
» WTB 460 flywheel
