429 boss
429 boss Empty 429 boss
Post  cesarperez November 17th 2017, 3:53 pm
what is the largest stroke crank in a 429 boss block
cesarperez
429 boss Empty Re: 429 boss
Post  dfree383 November 17th 2017, 4:21 pm
4.500 goes in with no issues, just make sure you get the boss snout if it's an origional boss motor and you want to keep the original accessories
429 boss Empty crank
Post  cesarperez November 17th 2017, 4:25 pm
i thought a 4.750
cesarperez
Post  dfree383 November 17th 2017, 4:31 pm
It will fit but the Pistons get pulled out the bottom pretty far, I wouldn't use one for any street application that you want to last, 4.500 is where I'd draw the line
BOSS 429 likes this post
Post  BOSS 429 January 18th 2024, 9:49 pm
I know old post
4.750 with a good size dome will call for a 6.600 rod, Which as stated above will pull piston down too far and wear out the skirts quick, about 40 runs on a set of pistons avg. Now its another story if you have a litle DOME. Then if you can use a 6.700 rod in a 10.300 deck block. But you could go with a 4.600 stroke and that will work fine.
