F600 370” crankshaft
F600 370” crankshaft Empty F600 370” crankshaft
Post  460bronco November 26th 2017, 11:01 am
What are the chances one of these motors has a steel crank? Also, what’s the easiest way to determine if the crank is indeed forged?
Thanks,
Jon
460bronco
460bronco
F600 370” crankshaft Empty Re: F600 370” crankshaft
Post  Paul Kane November 26th 2017, 12:15 pm
460bronco wrote:What are the chances one of these motors has a steel crank?
The chances are slim-to-none.
I have read all kinds of online forum speculation as to which of these industrial engines had the forged crankshaft, such as 2-BBL vs 4-BBL engines, etc, but none of that speculation proved true for me--of the 370s I've torn down every single one of those engines had a cast crankshaft.
460bronco wrote:Also, what’s the easiest way to determine if the crank is indeed forged?
Thanks,
Jon
Unbutton the pan...
Post  460bronco November 26th 2017, 12:33 pm
Thanks Paul! I don’t have enough experience of looking at different cranks and determining cast vs forged just by looking at them... I’ve had my hands on a factory cast 460 crank, a Scat cast 4.3” crank, and a Scat forged 4.5” crank. Never side by side though... what are some things I could look at to definitely say this 370” crank is cast????
Thanks again!
Jon
460bronco
460bronco
Post  Paul Kane November 26th 2017, 12:54 pm
460bronco wrote:...what are some things I could look at to definitely say this 370” crank is cast????
Thanks again!
Jon
The flip-side answer to your question: I can tell you what to look for to identify a forged 429 crankshaft.
The part number will be forged into the counterweight:
F600 370” crankshaft Forged1a
The wide parting line of the forging dies will be about 1/2-inch wide and very evident (as opposed to the narrow seam of a casting mold):
F600 370” crankshaft Forged2a
Post  460bronco November 26th 2017, 1:18 pm
Thanks again for the great info!
460bronco
460bronco
Post  cool40 November 28th 2017, 1:42 am
Bullet cams in olive branch can fix the snout and put any journal on it you want. they did a great job on mine. Very Happy
