Mr.Scharf's 1993 Foxbody Notch
D. Sea
MrScharfenberger
I'm moving my build thread to this site. It will take me a little while to get it all moved over so stay tuned...
I got this little jewel at a yard sale for $300 bucks. At the time the owner told me that it needed a transmission and didn't run. After I got it home I put 5 quarts of transmission fluid in it and proceeded to drive it for 6 months. I also had to change the oil. It was way over filled and it was RED fluid. I guess we all know what he did. Oh well. His ignorance was a great deal for me. Anyway I'll list the mechanicals and post up some pictures. I don't think the pictures are in any particualr order. I'm much further along than this first batch of pictures may suggest. I'll post more pic's later. Below are the motor spec's and mechanicals.
New motor is a 587 cid (9.4 liters). 4.560 bore x 4.5 inch stroke.
1999 SVO Block bored .030 over
UPDATE - 2015 Ford Racing A460 Big Bore Block
4.3 stroke Ford SVO Crank
UPDATE - Lunati Forged 4.5 Stroke Crank
UPDATE - Jon Kaase Aluminium Oil Pump
J&E Flat Tops
UPDATE - Diamond 4.560 Bore Pistons
Eagle H-Beams with ARP bolt upgrade
UPDATE - Callies Ultra H-Beam Rods
ARP Main studs
ARP Head Studs
SVO M-6049-A429 Cobra Jet Aluminium Heads
UPDATE - Jon Kaase P-51 Heads Fully Race Ported By Phillip Oakley at Oakley Motorsports
Lunati 51606 Solid Roller Cam (.735/.735) with matching roller lifters, valve springs & retainer kit.
Update: CompCams custom grind solid roller cam (spec'd by Lem Evans at B.F. Evans FORD)
Manely Extreme Duty Stainless Valves (2.25/1.76)
Ford Racing Chromemoly pushrods
UPDATE - Trend Chromemoly pushrods
Crane Gold Race Roller Rockers (1.73)
UPDATE - Comp Chromemoly Roller Rocker Arms
Comp Cams Rocker Stud Girdle
UPDATE: Jomar rocker stud girdle
Edelbrock 4150 Victor 460 Intake (I really want the Mafia intake though)
UPDATE: TrickFlow Mafia 4500 style intake
Choice of Carbs:
QuickFuel Q Series 4150 1050 Carbuerator
--or--
QuickFuel E-85 4150 1050 Carbuerator
Update: QuickFuel QFX 1450 CFM Carb
Aeromotive SS Electric Fuel Pump
Update: MagnaFuel ProTuner 750 Series In-Line Fuel Pump
Aeromotive Bypass Style Regulator
Aeromotive A1000 Carbureted Bypass Fuel Pressure Regulator
CSR 2 Inch Open Spacer
Update: Jomar 1 1/2 inch power cone spacer from Lem Evans (THANKS LEM!!)
CSR Electric Water Pump (natural finish)
Update: Star Machine Standard Vacuum Pump & drive mandrel kit from Phillip Oakley at Oalkey Motorsports
MSD 6AL Ignition Box
UPDATE: MSD Digital 7 (7530T) ignition box with HVC coil
UPDATE: MSD Flying Magnetic Crank Trigger
MSD 8577 Mechanical Distributor
NOS Big Shot Plate System
Harwood 6" Cowl Lift Off Hood
Mad Dog Headers ( 2 inch primaries with 3.5 inch Collectors)
Update: Custom made headers 2 1/4 primaries into 2 3/8th step collectors with 5 inch exit
Power Master 140 Amp Alternator
Power Master High Torque Mini Starter
Dougs Electric Exhaust Cutouts
Summit 10 Gallon Fuel Cell
8 AN Braided Fuel Supply & Return Line
AN Fittings Galore
UPR Front K-Member
UPR A Arms
UPR Caster/Camber Plates
UPR Manual Rack Bump Steer Kit
QA1 Front Struts with Coil Over 175 Pound Springs
Strange Drag Race Front Disc Brakes
Update: Strange Drag Race Rear Disc Brakes
Griffin Radiator (with CSR over flow)
Flex-a-Lite 13 1/2 inch dual puller fans (4600 CFM)
TCI Full Competition C6 Reverse Manual Valve Body with Trans Brake
TCI 4500 RPM Stall Converter
TCI Trans Cooler (huge x large)
UPDATE - Abruzzi "Mac Daddy" Powerglide Transmission
UPDATE - Abruzzi 10 inch 5900 RPM Torque Converter
B&M Mega Shifter
P.E.M. 3 inch diameter chromemoly driveshaft via Cale Aronson
UPDATE - Strange 3 1/2 inch chromemoly driveshaft 1350 Solid U-Joints
Ford 9 Inch Rear (setup for stock style suspension)
UPR Upper & Lower Control Arms (with aluminium bushings)
Moog 4 banger rear springs
Strange Drag Race Adjustable Rear Shocks
Moser 35 Spline Axles
Strange Pro Nodular Iron Center Section (Full Spool with 3.62 Pro Gear Set)
Billet Specialties 15 x 10 Rear Wheels
Mickey Thompson 28x12.5 ET Streets
Billet Specialties 15x3.5 Front Wheels
Mickey Thompson Sportsman tires (skinnies, I can't remember the size)
Jegs Mild Steel 12 poit cage kit
Scat ProCar Seats
G Force 5 Point Harnesses
There went tuition for one of the kids... The world needs ditch diggers too!!
$50 bucks says I forgot at least 20 other things... LOL
Oh yes... Like the motor plate and FluidDamper Harmonic Balancer!
UPDATE: Innovators West Harmonic Balancer
What she looked like the day I got her!!
A tired old 2.3 litre with 102.000 miles on the clock.
Battle Box Reinforcements In And Welded.
12pt Cage In And Welded. (Hot Rod #3 in the background. Sorry... It's a bone stock chebby)
Another Cage Picture.
Hood That I Got From A Guy On CraigsList In Cincinnati. $150 Bucks. What A Deal!! It Fits Perfect!!
View Of Hood Cowl From The Inside.
Greasey Ugle Mess.
More Greasey Ugly Mess...
J&E Flat Tops
ARP Main studs
ARP Head Studs
Choice of Carbs:
--or--
AN Fittings Galore
UPR Front K-Member
UPR A Arms
B&M Mega Shifter
Scat ProCar Seats
Greasey Ugle Mess.
Re: Mr.Scharf's 1993 Foxbody Notch
It would only let me post 10 pictures at a time. Here are the last 2 for now...
Rustoleum!! A Miracle Worker!!.
Finally!! All the rubber crap scrapped off the inside floor From Firewall to Trunk. That took a LONG time.
More pic's..
Brand New Billet Specialties Wheels & Brand New Mickey Thompson's. Life is good!!
Griffin Dominator Radiator & UPR Caster Camber Plates.
QA1 Struts with UPR Coil Over Spring Kit With 175# Eibach Springs. UPR K-Member & A-Arms
Rear Slotted Rotor Disc Brake Kit & UPR Control Arms.
Summit Racing Foam Filled 10 Gallon Fuel Cell. Interior Is Now Fully Painted Firewall To Trunk As Well.
[quote=BigBlockRanger;1002235]You do nice work![/quote]
Thanks!! I really don't know what I'm doing... I'm just making it up as I go along. I could really use a mentor. This site is as close as that gets. But at least I had the sense to build a BBF!!
[quote=BigBlok86Ranger]Did the rear springs start settling yet Chris?[/quote]
Not yet. I don't have the motor or tranny dropped in it yet though. With any luck that will happen this weekend and she will sit down more on the rear wheels. The Strange front brake kit will get here today. Once I get that on I'll be able to set it down on the wheels and get the motor in for a mock up. I still need to run the front bars for the 12 point cage into the engine bay that will attach to the motor plate as well. I'm still not sure if I'm going to hide them in the front fenders and then bring them back in after I pass the strut towers or if I should run them through the strut towers. Time will tell. Any suggestions on how to do that part are welcome.
[quote=Taxman;1002222]Will you be OK with 28x12.5s without a tub?[/quote]
After I got the rear end in I sat it down on the tires. Everything cleard fine. The only place I was concerned with is the front part of the fender at the bottom. It looks like I only have about a 1/2 inch of clearance. If these tires get taller at 100 miles an hour like I think they should I may have an issue. I may have to clearance the fender slightly to make it not rub. Once I get the front brakes on and it sitting on the ground I'll take a picture and show you what I'm talking about.
Other than that they look great. I went with the Billet Specialties wheels instead of the Weld wheels because the billet specialties were an SFI spec wheel. I'm not sure if I needed them or not but it wasn't much more money for the same style wheel.
....i also have dreams of sticking a set of 2.25:1 gears under it and taking it to Bonneville!! I want to join the 200 MPH club.
Hear that Blown473?? I'm going to make a run at thet fire breathing pickup you are building!!
[quote=bigblok86ranger;1002271]Only seen that tight of clearance with 29's maybe once the rear springs settle the axle will move back.[/quote]
The UPR control arms have adjustments for both the upper and lower. When I installed them I put them in at the recommend setting. I think it was 9 1/4 inches for the top control arms and 17 1/2 for the lower control arms. I could move it a bit that way. I'm not sure how much the axle will move back with weight on it. With those control arms on it, it is amazingly snug in there and really doesn't budge. It will obviously go up and down. But there is no side to side or front to back movement what so ever. I'm not that worried about it. I'll be sure it is right before I go to the track.
Got any suggestions as to how to run the front roll cage bars into the engine bay? Read the previous post I did in this thread for more details.
[quote=droppedf100;1002279]Everything looks great so far but aluminum dash? Also what ever happen to the truck?[/quote]
Yep. Just a flat piece of aluminium to hold the gauges. Nothing fancy.
I still have the truck. It is still set up to drag race. I have about (and I'm guessing here) a 425 horse power 466 engine in it now. It keeps up with the Corvette up to about 90 mph. Then the Corvette runs away. I'll keep the truck forever. I like it to much to get rid of it. Plus it will pull the Mustang to the track and back. I'd like to race the Mustang and the truck. You know pull in the track with the truck with the Mustang on the trailer and run them both while I'm there.
[QUOTE=MrScharfenberger;1002311]I really hope so... I'm sick of working on it. I'm ready to drive it. I've been busting butt on it again so hopefully I'll have it cranked out by spring.[/QUOTE]
Hey Thanks!!
Below is a link to the radiator on Summit Racing. It is a direct fit. I have to say as well that I was impressed with it when I pulled it out. It looked really good. I was concerned with it being only a 2 core. But the cores are huge. I've never seen cores that big.
http://www.summitracing.com/parts/GRI-8-00165/
I put a Griffin radiator in my sbf Pinto and they work great. It would keep things cool at 100* in Louisiana. I have a Northern Radiator in my 56 and it gets a lot hotter in a traffic jam with the same engine from the Pinto.
jasonf- BBF CONTRIBUTOR
Welcome to the real BBF Forum
D. Sea- Posts : 2768
2018 update?
I know I started this thread and then proceeded to not update it. I believe I'm going to only updated here from now on. The other site appears to have died. Oh well. Things change. If anybody wants to see the original build thread it is here:
https://www.460ford.com/forum/45-car-buildup-forum/157117-mr-scharfs-1993-foxbody-notch.html
OK... So now going forward I'll be posting on this site instead. With that being said... Hello Bruno & 385 family members!
I've been working on the car a lot. I finally have my barn clean so working on the thing is a pleasure again. I recently bought a Zex Perimeter Plate system & bolted it on. The results of the install are below. Some of you may know that I went on Hot Rod Drag Week this year with my other Mustang. I'd really like to get this one on Hot Rod Drag Week one year but I'll need a different motor build for that. Lem & Phillip...are you in to help build another motor specifically for the purpose of Drag Week? I'll reach out & talk to you guys soon if I don't hear back. I know you are busy.
Zex Perimeter Plate Install Results:
And finally the clean man cave!
Now all we need is spring to get here.
Stay tuned...
Stay tuned...
Last edited by MrScharfenberger on February 19th 2019, 1:28 pm; edited 7 times in total
Welcome back it was 81 here today in South Georgia
No pictures
Mike R- Posts : 1381
Mike R wrote:No pictures
I can't see them either.
Jess
Mustang-junky- Posts : 438
Can you see the pictures now? Is so I have some more updating to do...
MrScharfenberger wrote:I know I started this thread and then proceeded to not update it. I believe I'm going to only updated here from now on. The other site appears to have died. Oh well. Things change. If anybody wants to see the original build thread it is here:
Stay tuned...
I don't see them.
Jess
Jess
» 1993 Mustang Notch True Street Car
» Foxbody Mustang, Notch F/S...... Roller.........
» Name this part!
» 25.1E double frame rail 80 notch
» 1990 Mustang Notch Chassis Race Car
» Name this part!
